It is currently Wed Oct 17, 2018 1:37 pm
Post new topic Reply to topic  [ 6 posts ]
PostPosted: Tue Jan 13, 2015 12:05 pm
I am sure we all have done it. Seized the clutch rod/ball setup. Here is a kit that will eliminate it. It contains a flat roller bearing and plate that allows the adjuster screw to rotate. This gives the clutch components 1 more additional rotation point that is needed. Also includes a Ceramic ball that will not break or have a seizure.
Available at TDR : http://www.bansheedepot.com/proddetail. ... =24%2D5776
$47.00 Shipping by Priority mail $6.00
Just PM me or contact me direct 941-505-0800
http://www.tdrracing.com
www.tdrrz.com
PostPosted: Tue Jan 13, 2015 2:32 pm
is this RZ only or compatable with LC as well?
thanks mark
2004 BMW R1150RT
1989 FZR1000
1994 FZR1000
PostPosted: Tue Jan 13, 2015 3:32 pm
I am not 100% sure but I do believe it does fit the LC as well. Have to do some more research.
www.tdrrz.com
PostPosted: Fri Jan 16, 2015 12:30 am
LC has a different clutch set up, actuator arm and adjustment is done from the left spline drive. RZ is right central on the clutch.
81Rd350lc resto 2016
81 Rd250lc resto 2017
1999 ZRX 1100
PostPosted: Fri Jan 16, 2015 9:08 am
Thanks for that Richard.
2004 BMW R1150RT
1989 FZR1000
1994 FZR1000
PostPosted: Sat Jan 17, 2015 11:51 am
Suppose I should have bought this while my side cover was off.
cron
