Hi all, i had an issue with the bike (4LO) which i recently got.
the flashers would work a bit at first but soon stopped all together.
i opened the handlebar switch and it was a horrible corroded mess so assumed that was it.
got a nice replacement switch and indicator stem/bulb assembly and they work again but one side wont flash .
all bulbs light up (including the dash bulbs).
why would one side blink but the other will not.
electrical stuff defo not my bag
any help is greatly appreciated.
cheers mark
1982 350LC flasher prob
- two-stroke-brit
1982 YAMA RD350LC
98KDX 220R
1967 TRIUMPH TIGER
2001 TRIUMPH TT600
1982 YAMA RD350LC
98KDX 220R
1967 TRIUMPH TIGER
2001 TRIUMPH TT600
- steveloomis
Re: 1982 350LC flasher prob
Are all the bulbs EXACTLY the same? The load must be matched, if not enough load, the flasher will not flash. Just make sure the bulbs are the correct wattage and the same on all 4 indicators (Turn Signals in the US). In the US an indicator is like the arrow on your dash that flashes with the other bulbs.
Steve
Steve
'81 RD350LC hybrid w/84 RZ engine. Zeel, Old style Toomeys, Yboot and filter 420 main 22.5 pilot, Air screw 2.5 turns out, DJ needle 2nd from top, Canadian VM26 carbs.
'85 KR/RZ US. Tank is seeping causing a blister in paint.....
- two-stroke-brit
cheers steve i will check tomorow
1982 YAMA RD350LC
98KDX 220R
1967 TRIUMPH TIGER
2001 TRIUMPH TT600
1982 YAMA RD350LC
98KDX 220R
1967 TRIUMPH TIGER
2001 TRIUMPH TT600
- pushstartrearset
i got around the load problem doing this (1 way to do it):
https://www.youtube.com/watch?v=8GoU3qLNp4I" onclick="window.open(this.href);return false;
- two-stroke-brit
hi all , i cleaned up the connections and replaced the flasher unit with auto one and they all work.
thanks again mark
thanks again mark
1982 YAMA RD350LC
98KDX 220R
1967 TRIUMPH TIGER
2001 TRIUMPH TT600
1982 YAMA RD350LC
98KDX 220R
1967 TRIUMPH TIGER
2001 TRIUMPH TT600
- pushstartrearset
glad it worked for you. Have to do the same mod on the 85 we have...funky flashbulbs on that one too (period flush mounts for the Spec II bodywork).
