Flywheel lightening
Moderators: rztom, 2smoke
RuZty
Re: Flywheel lightening
#16 Post by RuZty » Sat May 19, 2018 10:35 pm
Why dick about modifying 30 year old motorcycles? Find and buy a faster motorcycle, for a genuine improvement?
There are plenty available. Not free, but then nothing new ever is.
....unless you enjoy dicking around with old motorcycles, then carry on. :smt002
(F5)
#17 Post by (F5) » Sun May 20, 2018 5:09 am
Hahaha.
Thanks for posting. :smt003
RuZty
#18 Post by RuZty » Sun May 20, 2018 6:29 am
A quick calculation puts the difference in inertia of a 2 mm cut to be about -16%, not bad for free. [smilie=cool.gif]
Bare
#19 Post by Bare » Sun May 20, 2018 11:16 pm
RuZty wrote:Why dick about modifying 30 year old motorcycles? Find and buy a faster motorcycle, for a genuine improvement?
Being a hapless Dick are we?
It's possible to buy an Ignitech or Dynapower flywheel/ stator assly. Designed to fit the Yama 350 engine
Which is Purpose designed to be Lighter for performance reasons.
Shaving a few mm off of the oem Yama flywheel is V close to pointless.
LC Cnd
#20 Post by LC Cnd » Fri Jun 08, 2018 12:56 am
Done. Be interesting to see what the result will be on the throttle. Created a woodruff key in an inverted 'T' shape to tightly fit the worn/widened channel in the flywheel to fit tight.
hondaror
#21 Post by hondaror » Sun Jun 10, 2018 4:20 am
Keep us posted.
Hooligan
#22 Post by Hooligan » Fri Aug 10, 2018 2:25 pm
hondaror wrote:Yeah, wow, that one is cut down. That looks like a fun mod. I might have to try that.
As far as balancing goes, drilling small divots where it is heavy, is effective.
And how do you know where it is heavy?
'85 FZ750
Hooligan
#23 Post by Hooligan » Fri Aug 10, 2018 2:28 pm
LC Cnd wrote:I get that balance is key - can this be acheived in a static balance setup, like balancing a motorcycle wheel, or does the flywheel have to be in constant motion to find where to drill to balancing out? Found this photo'd sample on a Harley form. Then there is the question of how much to drill that's the challange. The video, on shaving a flywheel, stated that is not a issue interestingly.
I suspect that turning the OD of a flywheel would not affect the balance. It would simply take off the same amount all around the flywheel.
If anyone has a spare flywheel they'd like to donate, I have all the equipment to do this mod. I even have a tire balancing stand and could make up bushings to mount the flywheel.
'85 FZ750
Hooligan
#24 Post by Hooligan » Fri Aug 10, 2018 2:31 pm
If someone YAMAHA would simply build this thing then I wouldn't have to dick around with old motorcycles.
'85 FZ750
Hooligan
#25 Post by Hooligan » Fri Aug 10, 2018 2:33 pm
RuZty wrote:A quick calculation puts the difference in inertia of a 2 mm cut to be about -16%, not bad for free. [smilie=cool.gif]
Its not free. It requires ca $10k in machinery and tooling not to mention the years of machining experience to do it correctly. :smt021
'85 FZ750
RuZty
#26 Post by RuZty » Fri Aug 10, 2018 9:00 pm
Free if you already have those things at your disposal. :smt002
Hooligan
#27 Post by Hooligan » Fri Aug 10, 2018 9:45 pm
Sweat Equity is NEVER free. I've burned myself and cut myself and broken stuff and spent hours upon hours learning how to do this stuff.
'85 FZ750
hondaror
#28 Post by hondaror » Sat Aug 11, 2018 4:11 am
There are ways.
Hooligan
#29 Post by Hooligan » Sun Aug 12, 2018 12:37 am
VERY helpful :smt017
'85 FZ750
hondaror
#30 Post by hondaror » Sun Aug 12, 2018 2:50 pm
Across two scales. Measure, Mark, rotate. You have to calculate, but it works.
