Electrical Gremlins - RD350LC
RZ350GUY
#1 Post by RZ350GUY » Tue Sep 10, 2019 3:05 pm
Hi folks - For the Canadian version, 1982 RD350LC, the turn flasher lights, meter lights, horn and rear stop light work on DC current/battery or do they work of the magneto generator/AC current? I know that the headlight works of the AC generator. I am restoring an LC and its all original, wiring, fuses intact etc. I am having a hard time figuring this one out. Thanks for your help.
waltmil
Re: Electrical Gremlins - RD350LC
#2 Post by waltmil » Tue Sep 10, 2019 7:38 pm
Um, I think everything except the ignition works on the DC (battery) but I could be wrong.
tacky1
#3 Post by tacky1 » Tue Sep 10, 2019 10:03 pm
Everything works off the battery,
BUT, They will all work with a dead battery if you start the bike..
evan_calgary
#4 Post by evan_calgary » Wed Sep 11, 2019 12:48 pm
Thanks for confirming that Tacky. I almost had to go pull some parts to confirm it was all 12V and to make sure I wasn't going crazy. Anything that may generate by AC is converted DC 12V asap before going anywhere.
RZ350GUY
#5 Post by RZ350GUY » Thu Sep 12, 2019 12:52 am
Gentlemen: Thank you all for your help. This is my very first RD350LC, therefore I was not very familiar with the lighting etc. I had assumed that all lights work of the battery except the headlight. I re-checked the fuses and right enough the main fuse on the red wire was defective. After relacing it, the lights now work off the battery, including the brake light etc. The only light that is still non-functional is the rear parking light. I will try and sort this out in the morning and report back.
evan_calgary
#6 Post by evan_calgary » Fri Sep 13, 2019 4:08 pm
Good to hear you solved most of your problems.
Get out the multi-meter and start checking wiring runs. It is potentially that or a corroded bulb connector. Most common issue from a first look.
Some headlights/horn etc will only operate when the motorcycle is running but not case with RZ.
RZ350GUY
#7 Post by RZ350GUY » Sat Sep 14, 2019 3:59 pm
Thanks Evan to you and all the rest for your help.
You are spot on! The connector was corroded inside the insulation at the brake/stop light end holder!All sorted now.
