A couple pictures of my project bike**Now finished!!
So i will start with a couple pictures of my project bike. Sorry they arent better but the weather hasnt given me a chance to get it outside yet.
I have mainly been collecting what i need to finish it so far. I will start a project thread soon.
79 RD400F Daytona Special
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
- aaronmvrider
wheels
Wheels are painted with Rattle can PJ1 or VHT
I noticed the color is extreemly close to the gold on my RZ500 stock wheels.
I guess i am going to use this as my build thread for this bike.
So i will give some background info and my plans for it.
Which can and will change at any time
Ok so first of all, a big thanks to Nocturnal and his dad, who sold me this bike for a great price. His dad has 2 more LC`s still so he wont miss this one. The guy they got it from owns a media blasting company and he stripped and powdercoated the frame and swingarm black, stripped and painted the gas tank and bodywork.
The engine looks stock and fairly fresh. I peeked into the cylinders and everything looks good. I will be taking off the clutch cover so i can look in there too, but i am going to run it this summer without splitting the cases.
The bike is currently setup for premix, with an oil pump blockoff plate.
I already sourced a complete oil pump and will be using that and rejetting and all that fun stuff.
The bike came with a set of stock exhaust in good shape, and a set of RZ350 spec2 chambers with brackets to make them fit the LC.
Bike came with 1979 RD400 upper and lower triples(35mm dia.) and 1986-newer cdn RZ350 forks + calipers, and generic clipons.
I want this bike to look pretty stock but with some improvements.
Heres my plans for the bike this summer:
I have sourced a set of early RZ350 forks and triples(35mm vs 32mm orig on the LC) to use with LC or early RZ fender
I have brand new Yamaha 4LO handlebars
Front brake calipers and master will be something better, i have`nt decided what yet.
Oil pump installed
Black mars bar paintjob with the gold wheels.
Leaning towards using the spec2 chambers for now, i like the stock pipes but i gotta hear this thing!
And all the usual stuff, fix the harness, change the head bearings...etc.
By the way, I found out that the LC oil pump and gears etc. are the same as the RZ350.
Oil pump installed
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
They are identical. RZ ones say 4L1. Yamaha has superseeded the 4L0 part number to the RZ 1UA number. And the gears etc are the same too.aRZed wrote:Colin, from what you know of the oil pump, can I fit a LC oil pump and gear to a '86 RZ350 motor without any changes? The pulley is stamped 4L1.
Sean
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
- Moderator
- aaronmvrider
- Moderator
lc
I had some progress today so i thought i would post an update.
The bike came with these 86 RZ forks (which use the topmount fender) and clipons.
Unfortunately i want to use handlebars and the original sidemount fender. So i pulled that stuff off.
And after changing the bearings for some new allballs tapered rollers, i put on some 84-85 RZ350 USA forks, with fresh powdercoated upper triple and new handlebars.
It worked out well because these forks use the same axle, and they have 4 bolts in the lower triple so they can mount the horn bracket.
I can use the original fender if i make some spacers. It is more narrow than the RZ fender because the wheel is narrower.
My horn bracket is a little bent so i have to straighten it out. I Still have to decide what brake calipers to use.
And i need some headlight mounting brackets for 35MM forks. I might be able to modify the original ones for 32MM forks to fit, we`ll see.
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
- winner_evo
Re: lc
2smoke wrote: I Still have to decide what brake calipers to use.
These Harrison 4 pots bolt straight on 4l0/31K forks without the need for adapter brackets......
Pretty hefty price to buy from the retailer but I bagged a pair of these new ones for a lot less than half the retail price. Going to anodise them black before I fit them to my white bike.
Another nice option for an LC is the classic AP Racing/Lockheed CP2696 twin piston caliper and NK Racing already make brackets for them.
Oooooooh. nice wheels.
Maybe some new tires though. Lol!
Not much new to report on this project i am afraid.
I bought a new decal set from reproductiondecals.com and i am having a guy i trust spray the bodywork gloss black. Dropping it off Monday. I have realized that if i want to ride this bike this summer, i cant do it all myself.
I might have found an option for the brake calipers.
I dont want to say what they are until i know for sure.
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
