If they want to use sand make sure it is a fine sand. You will have a better final texture to the frame once powder coated. Usually something that large will not fit in the bead blasting booth from my experience. If they are cool with using beads then ignore!
Ensure the powder coater is well aware of the threaded bolt holes that need to be protected form powder otherwise you will have lots of work with taps. Some do this as they should without questions and some will coat hte threads if you don't specifically urge them not to.
