Triumph Hinckley Bonny
We love ALL motorcycles - post your non-2T custom build here!
Headcoats
Post by Headcoats »
This was how it was
Been after one of these for a while :smt002
Was standard but pulling bits off to make it lighter and meaner ,I hope LOL :smt003
Re: Triumph Hinckley Bonny
Post by Smoker »
Damn! That's a beauty. :smt004
I'd pull off that sofa lounge seat. Looks like 4 people could sit on it. :smt003
T.RexRacing
Post by T.RexRacing »
Try buying the right bike and keepin' it stock. And ride. I dare ya.
Salvador Dali
Headcoats
Post by Headcoats »
T.RexRacing wrote:Try buying the right bike and keepin' it stock. And ride. I dare ya.
Never :smt003
Headcoats
Post by Headcoats »
This is a pic of the bike that made me want to get one :smt025
If you look at the side panel it has 904 on it as in a big bore kit :smt001
Headcoats
Post by Headcoats »
Got these shorty silencers,just need to get them to fit now as they are a universal silencer
Headcoats
Post by Headcoats »
http://www.way2speed.com/2014/07/triump ... z3I8vFIVAp" onclick="window.open(this.href);return false;
Been getting a few parts together as I thought I had decided the look I wanted but then spotted the link above :smt035
Headcoats
Post by Headcoats »
It's back on it's wheels :smt003
Better get a pic sorted :smt024
Headcoats
Post by Headcoats »
Looks like the first pic but a lot has gone on LOL
Headcoats
Post by Headcoats »
Just got some Thruxton header/down pipes which are slightly longer and flare out a bit wider compared to the original down pipes.
This means the universal silencers I got have a better chance of fitting once I get a link pipe made
Headcoats
Post by Headcoats »
The Angel Eye headlamps we all fit in our LC's over here fits perfectly in the Triumph's headlamp shell :smt004
Fits better actually than it does in the LC :smt033
Headcoats
Post by Headcoats »
Been putting it off but now delving into the carbs !!
They are CVK 36 Keihin carbs with heaters ,TPS and stuff so pretty different to the PWK 28 carbs I have been messing with the last several years :smt027
The idle mixture screw has perished 0 rings and one washer missing so looked on the Triumph microfiches and you have to buy the complete screw which is £23 per screw :smt022
Just need to find some Viton 0 rings and a tiny washer then :smt011
Really clean inside but the slides have a little scoring on the engine facing side but look new airbox facing side :smt017
Post by hondaror »
That's normal. The air blowing by forces the slides to scrape the engine side, wall.
slow86gn
Post by slow86gn »
Richard at Mule motorcycles makes some trick parts for those bikes. Alot of his bikes are flat tracker style. http://mulemotorcycles.net/" onclick="window.open(this.href);return false;
1985 RZ350NC. 1979 RD 400 Dayton Special 2015 KTM 690 DUKE
Headcoats
Post by Headcoats »
Must have been ignoring the rear end
So need to sort out
Rear disc worn out
Brake pistons corroded
Brake hose corroded fittings :smt010
