Windscreen fasteners for RZ350?
Posted: Thu Aug 14, 2014 8:30 pm
by dauer
As the title states I'm trying to source OEM style windscreen fasteners for my '84 RZ350 KR, I discovered they are no longer available from Yamaha. I searched various sites but came up empty until I found a kit from economy cycle, unfortunately they are 5mm not 4mm. Any info or leads would be appreciated. Thanks
Re: Windscreen fasteners for RZ350?
Posted: Thu Aug 14, 2014 8:56 pm
by RuZty
5mm drill?
Posted: Thu Aug 14, 2014 9:36 pm
by silverstrom
Ron Ayers still shows them as available.
http://www.ronayers.com/FAIRING-COWLING-C484596.aspx" onclick="window.open(this.href);return false;
The 86-90 hardware is still available from Yamaha. Those are plastic screws. Are the 84 screws plastic?
Posted: Fri Aug 15, 2014 3:18 am
by aaronmvrider
yes plastic 84
Posted: Fri Aug 15, 2014 7:25 pm
by dauer
silverstrom wrote:Ron Ayers still shows them as available.
This is very helpful, thank you.
Posted: Sat Aug 16, 2014 10:30 am
by AK Addict
Hopefully Ron Ayers does have them but I've found they don't keep there fiche updated, order parts listed as available only to get an email later that they can't get them. Partzilla does a better job of keeping there fiche updated. I've read that you can tell by the part number the size of the screw but I'm unsure what number in the part number to use.
90157-04062 84-85 USA model
90150-05020 89 Canadian
I'm guessing the 90157-
04062 is 4mm and the 90150-
05020 is 5mm?
Is that correct?
Posted: Sun Aug 17, 2014 8:47 am
by nokturnal
I have a set stashed. they are metal. olivish
Posted: Sun Aug 17, 2014 11:54 am
by dauer
My screws are 4mm, the ones I got from economy cycle are 5mm. I was unaware of this until they arrived ay my door. I'm going to send out a few emails this week and see what I can find out.
Posted: Mon Sep 01, 2014 11:09 am
by dauer
Thought I might update my findings. My search for OEM screws proved fruitless. However I did discover that the 5mm screws from economy cycle fit with no drilling. May have been wise to check that before starting a thread on it... None the less the 5mm are a nice fit and also beefier than the tiny OEM screws that tend to either vibrate out or snap.
Posted: Sun Aug 21, 2016 4:42 pm
by concours
I found the correct M4 x .7 x 12 black nylon phillips pan heads here:
http://www.mcmaster.com/#nylon-screws/=13tpltt" onclick="window.open(this.href);return false; P/N 92492A222
They also have large flat washers that are a perfect fit here:
http://www.mcmaster.com/#standard-washers/=13tplc0" onclick="window.open(this.href);return false; P/N 90377A137
And the nuts....
http://www.mcmaster.com/#hex-nuts/=13tpkbf" onclick="window.open(this.href);return false; P/N 98676A200
I was all set to buy a bunch, sell kits to those that needed them, but then I found my missing one when cleaning the bike lift. I hope it helps some others.
