It is currently Tue May 22, 2018 1:24 am
 Post subject: TZR250 2MA/1KT Swingarms
PostPosted: Fri Apr 20, 2018 3:55 pm
I have a couple spare TZR250 2MA swingarms. They appear to be very close to the same width as the RZ at the swingarm pivot. The shock setup is also similar. I have not done a conversion before though.
These are all aluminum box section swingers that are very light. Think I have one set of axle adjusters but would have to confirm. Otherwise bare. I can weigh one if requested.
Seems like a lot of people go for the FZ600 swinger. Not sure why when TZR250 is lighter and allows for some proper width wheels still.
$250/per.
Can ship on USPS for like $20 anywhere CONUS.
PostPosted: Sat Apr 21, 2018 7:11 pm
Can you please post or IM pics? What is the pivot width in mm? Thanks!
PostPosted: Mon May 07, 2018 10:33 pm
Here are some dims
Stock F2 swinger 4.25kg
TZR arm 2.8kg
RZ350 rear ID 214mm
TZR rear ID 207mm
RZ350 pivot length 201mm
TZR pivot length 201mm
TZR pivot bolt diameter 16mm
TZR rear axle bolt 15mm
Get some pics up in a bit
$200/each.
PostPosted: Sat May 12, 2018 6:54 pm
I’d be interested in one. I’m in Vancouver. Can you send over a pic or two?
PostPosted: Sun May 13, 2018 6:51 pm
Pictures of one here:
https://drive.google.com/open?id=1N9zGi ... wZ3m8r6641
Can include brake support, pivot bolt and bush, and likely adjusters (maybe rear axle)
PostPosted: Wed May 16, 2018 11:57 pm
How wide of a really wheel did these bikes run?
85 RZ350-Messed up wiring
PostPosted: Thu May 17, 2018 1:04 pm
2.5" I believe. Narrow is good on these old bikes.
