It is currently Sun May 20, 2018 7:34 am
PostPosted: Sat May 12, 2018 6:58 am
Hello Gents. I have been in and around the rz side of this forum. This week i picked up an Australian 1981 rd350r 5eo. I got it from a guy who had owned it for 20 years. 4 years ago he rebuilt the engine and replaced many other parts to get it back on the road. He had a change of fortune and decided to sell the bike and contacted my local yamaha dealer, asking if they knew of an enthusiast?? Seems all that money i have spent there has paid of because they called me. I worked out a deal with him and the bike is home and i'm in love. My first road bike was an rdlc250 that i bought for $500 in 1987. I stacked that bike on loose gravel and cracking a bone my arm. My mother found out and made me sell the bike (her words, "i'm not going to your funeral, get rid of it"). I never forgot the rush of the lc power band, so here i am with a bike i have wanted to own for a long time.
The bike has been fitted with a hot rods banshee crank, +2mm pistons, new matika billet clutch basket, had some minor porting (exhuast port raised 1mm), carb kits, seals etc. Has new tyres, brake discs, calipers rebuilt, swing arm and headstock bearings replaced. It has some nice chambers, (apparently sagaya chambers japan??)
In all most of the major things have been done, essentially it needs to be painted and mirrors, stock bars and indicators fitted. I will be going with original. I would like to fit a pro am bikini and lower fairing at some point.
I spent a few days going over the bike adjusting and checking settings. Today i took it for a shake down ride on a country road to get a feel for how it and start to run it in. The bike went really well and the fueling feels spot on. (stock jets and air box). I did notice a rattle a few times that i believe is the idler gear rubbing on the clutch basket.
I'm looking forward to spending allot of time on the bike. I'll also be on the forum asking questions and gaining knowledge about lc's.
yamaha fanatic.
PostPosted: Sat May 12, 2018 7:04 am
yamaha fanatic.
PostPosted: Sat May 12, 2018 7:06 am
yamaha fanatic.
PostPosted: Sat May 12, 2018 9:44 am
Coool! nice catch Graham and good backstory. :)
My Projects:
PostPosted: Sat May 12, 2018 12:26 pm
Moderator
Probably not a hotrods crank. Maybe a rebuilt oem or new Yambits one.
Unless the previous owner was a machinist.
Some missing bits on there. Some aftermarket bits too.
Enjoy and update us!
79 RD400F Daytona Special
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
PostPosted: Sat May 12, 2018 5:08 pm
I asked the previous owner if he machined the cases to fit the crank? The ends of the crank webs where machined to bring the outer bearings in to fit. The head has been shaved to get.09mm squish using a copper head gasket. Inlet side of Piston skirt has been shortened, Carbon reeds installed. The bike came with quite a few parts, including front gaurd, rear grab rail, original bars and master cylinder, stock pipes and pro amm bikini fairing. I've just removed the clutch cover to inspect the clutch and idler gear. The rattle noise i believe is idler gear. The noise is not constant and if i turn the bike of and re start it, it goes away. There is a small amount of movement on clutch basket. ( in and out) i wonder if the clutch thrust washers are worn. I'll replace the idler first.
yamaha fanatic.
PostPosted: Sat May 12, 2018 5:20 pm
https://youtu.be/CUvxLs6YgaM
yamaha fanatic.
PostPosted: Sat May 12, 2018 6:27 pm
Cool new bike Graham! I like it!
