It is currently Wed Sep 26, 2018 1:56 am
 Post subject: Lost piston pin circlip
PostPosted: Mon May 14, 2018 8:25 pm
Hi All,
While rebuilding my engine today I accidentally dropped the piston pin circlip into the crankcase. Just wondering what my options are? Can it stay there, I REALLY do not want to have to split the cases to get it out if I don't have to.
Thx.
J
PostPosted: Mon May 14, 2018 8:38 pm
It must be removed if the engine is to survive. Pick one of these magnets up (Harbor Freight,NAPA,ect.) and it'll probably come out. At worst you will remove the engine from the chassis and turn it upside down and shake it.
Salvador Dali
PostPosted: Mon May 14, 2018 8:53 pm
A borescope would be nice too to investigate. Hope you are able to locate it and remove it without splitting the cases.
PostPosted: Mon May 14, 2018 9:49 pm
Do NOT leave it in there.
It will lead to a catastrophic failure.
As others have said. Magnet or turn it upside down and shake.
Always, always, always put a paper towel stuffed down around the crank to stop this exact scenario from happening.
PostPosted: Mon May 14, 2018 11:08 pm
i reckon if you turn it upside down you risk it getting in the crank, use a magnet stick as shown above if it will fit, else its strip down time.
This is an advert for using a rag around the piston/rod covering the crankcase opening when doing this work.
My Projects:
PostPosted: Tue May 15, 2018 5:04 am
Should be fairly easy,
From a 4 stroke not so !
Stuff the crankcase mouths with rags next time :-)
PostPosted: Wed May 16, 2018 2:26 am
Yup, get it out of there!
PostPosted: Wed May 16, 2018 3:39 pm
Try blowing with compressed air and see if it pops out if you cannot get a magnet down there.
RD350 YPVS 1990
N2 Red/white - F2 conversion
Figaroli pipes
PostPosted: Wed May 16, 2018 7:17 pm
WooHoo... got it. Picked-up one of the magnetic tools. It JUST fit between the crank journals but boy did the magnet ever want to stay stuck to the crank! I bent the expandable shaft in the process.
Thanks for the advice!
J
PostPosted: Wed May 16, 2018 7:31 pm
Alright!!! Happy for you- now.... stuff those rags on both upper holes before trying to install those circlip!!!
PostPosted: Wed May 16, 2018 9:46 pm
Glad that worked for ya. So let's see the bike!
Salvador Dali
PostPosted: Fri May 18, 2018 4:05 am
Good work!
