It is currently Tue Aug 14, 2018 6:21 am
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
 Post subject: Re: Flywheel lightening
PostPosted: Sat May 19, 2018 10:35 pm
Why dick about modifying 30 year old motorcycles? Find and buy a faster motorcycle, for a genuine improvement?
There are plenty available. Not free, but then nothing new ever is.
....unless you enjoy dicking around with old motorcycles, then carry on. :smt002
PostPosted: Sun May 20, 2018 5:09 am
Hahaha.
Thanks for posting. :smt003
496 Cheetah. TSS PVs, PWK35s, Ignitech, RGV(ish) chassis
PostPosted: Sun May 20, 2018 6:29 am
A quick calculation puts the difference in inertia of a 2 mm cut to be about -16%, not bad for free. [smilie=cool.gif]
PostPosted: Sun May 20, 2018 11:16 pm
Being a hapless Dick are we?
It's possible to buy an Ignitech or Dynapower flywheel/ stator assly. Designed to fit the Yama 350 engine
Which is Purpose designed to be Lighter for performance reasons.
Shaving a few mm off of the oem Yama flywheel is V close to pointless.
PostPosted: Fri Jun 08, 2018 12:56 am
Done. Be interesting to see what the result will be on the throttle. Created a woodruff key in an inverted 'T' shape to tightly fit the worn/widened channel in the flywheel to fit tight.
PostPosted: Sun Jun 10, 2018 4:20 am
Keep us posted.
PostPosted: Fri Aug 10, 2018 2:25 pm
hondaror wrote:
Yeah, wow, that one is cut down. That looks like a fun mod. I might have to try that.
As far as balancing goes, drilling small divots where it is heavy, is effective.
And how do you know where it is heavy?
'81 RD350LC hybrid project bike - in pieces currently
'82 RD350LC in '81 colours - Built by "Solo 2" OEM pipes, UNI filters
'90 RZ350F2 with 31K motor, OEM F2 pipes & airbox
PostPosted: Fri Aug 10, 2018 2:28 pm
LC Cnd wrote:
I get that balance is key - can this be acheived in a static balance setup, like balancing a motorcycle wheel, or does the flywheel have to be in constant motion to find where to drill to balancing out? Found this photo'd sample on a Harley form. Then there is the question of how much to drill that's the challange. The video, on shaving a flywheel, stated that is not a issue interestingly.
I suspect that turning the OD of a flywheel would not affect the balance. It would simply take off the same amount all around the flywheel.
If anyone has a spare flywheel they'd like to donate, I have all the equipment to do this mod. I even have a tire balancing stand and could make up bushings to mount the flywheel.
PostPosted: Fri Aug 10, 2018 2:31 pm
If someone YAMAHA would simply build this thing then I wouldn't have to dick around with old motorcycles.
PostPosted: Fri Aug 10, 2018 2:33 pm
Its not free. It requires ca $10k in machinery and tooling not to mention the years of machining experience to do it correctly. :smt021
PostPosted: Fri Aug 10, 2018 9:00 pm
Free if you already have those things at your disposal. :smt002
PostPosted: Fri Aug 10, 2018 9:45 pm
Sweat Equity is NEVER free. I've burned myself and cut myself and broken stuff and spent hours upon hours learning how to do this stuff.
PostPosted: Sat Aug 11, 2018 4:11 am
There are ways.
PostPosted: Sun Aug 12, 2018 12:37 am
VERY helpful :smt017
PostPosted: Sun Aug 12, 2018 2:50 pm
Across two scales. Measure, Mark, rotate. You have to calculate, but it works.
