RZ vs LC clutch - forgive my failing memory
Which parts if any interchange? plates/springs I am wondering about mainly. tia
Re: RZ vs LC clutch - forgive my failing memory
different operating mechanism, but plates are close enough the same and springs will work in eachother, but part numbers are diff.
Thansk Jon.
Just trying to figure out if I can simply buy an RZ rebuild kit (which is more available)
Banshee parts are really easy to come by, They fit... I run banshee billet baskets and plates etc
Yeah RZ/banshee or FZ600 plates for an upgrade etc
TZ250 springs are wonderful.
Also.. Completely 100% unnecessary Best part of Yama 350s LC OR Rz is their light clutch action.
Adding Stoopid strong springs messes that.. Big Time.. For Zero actual reason .
IF one does a decent job of rebuilding their clutch and fitting Suitable frictions..
It's seriously unlikely one can build an engine able to slip the clutch.
If Not.. be happy while struggling with your clutch lever
I wore out 3 sets of clutch springs until I installed the TZ springs. Once the bike is running, the clutch action is way easier. Pick your poison, I guess.
How do you wear out clutch springs? How do you even know they are worn out?
Plates and frictions I can see, but not the springs themselves.
'85 FZ750
'85 FZ750
- two-stroke-brit
They have a tolerance on the overall length which decreases with fatigue.Hooligan wrote:How do you wear out clutch springs? How do you even know they are worn out?
mark
1982 YAMA RD350LC
98KDX 220R
1967 TRIUMPH TIGER
2001 TRIUMPH TT600
1982 YAMA RD350LC
98KDX 220R
1967 TRIUMPH TIGER
2001 TRIUMPH TT600
You'll know when they are done. Your plates look great but you've got high rev slippage. Ask me how I know.Hooligan wrote:How do you wear out clutch springs? How do you even know they are worn out?
Friction thickness can be surprisingly Slight betwixt Brand new and worn out .
IMO lotsa slipping clutches are worn out frictions based.
Takes a decent micrometer to be sure .
Eyeballs isn't enough Unless they are completely destroyed
There are drop in Oversized (as opposed to Stock) 350 size frictions giving 30% More friction surface,, sourced from a whole slew of Yamas up to XJ 1100s ?
Then there is the slight basket machining possible to shoehorn in 8 frictions for even more stiction.
AS well as bespoke Race frictions ...that Will Not slip if passably assembled.
One can even fit those locker/weight gizmos if Truly worried
TZ springs were for their seriously unreliable Dry clutch setups, which were actually easy to pull , like our wet ones.. despite their heavier springs.
