It is currently Fri Aug 17, 2018 4:49 pm
Post new topic Reply to topic  [ 10 posts ]
 Post subject: Powervalve parts
PostPosted: Fri Aug 10, 2018 7:08 am
Online
Hey everyone, I need a few powervalve parts. I need a right side powervalve and the right side cover with the bush/boss. I need a servo, cdi, servo control box, and head bolts. Please holler at me if you have any of this stuff! Especially the right side cover and powervalve! Thanks
 Post subject: Re: Powervalve parts
PostPosted: Sat Aug 11, 2018 9:42 am
Online
I know these parts a rarer than hens teeth, but someone out there has an old busted cylinder I know!! Please holler if you have rz right powervalve and cover! My yammagamma is depending on it!!! Thanks
PostPosted: Sat Aug 11, 2018 12:33 pm
sent pm for some of what you're looking for.
PostPosted: Sat Aug 11, 2018 7:21 pm
you can still buy quite a lot of PV parts new and Fast from the past has billet PVs for sale.
PostPosted: Sat Aug 11, 2018 9:52 pm
Ian- I may have some PV parts and head bolts if you still need them?
You can use a circa 2000- 2003 ? Yamaha R1 Exup for your PV servo controller- do a search here on Exup and read until you are content. Good news if they are cheap! Bad news is that the PV cables (2) are still available but expensive! The FFP billet PVs are nice (I'm running them) but may need some clearancing and fiddling for best fitment. On the CDI, if you are looking for a stock non programmable unit, Economy Cycle has the standard Zeel unit like the stocker- I run this unit too.
84 RZ350-Toomeys,SCR milled head, stk 26 carbs,300 M, 35 P, stock regrooved needles AS 2.5 turns out,stk air box,Banshee reeds Zeel non-progr CDI,TSRL Program YPVS,alum rad,R6 shock,GV emulators w/RT springs,fork brace,Shindy steering damper.
PostPosted: Sun Aug 12, 2018 2:30 am
Online
Thanks for the replys everyone, I was definitely not aware that you could get them from ffp. That's awesome. I'll definitely take you up on the head bolts Evans, but I might have some of the stuff found. Thanks again everyone!
PostPosted: Sun Aug 12, 2018 7:23 am
The head bolts and washers are also available from Yamaha new from $45-60 depending on dealer mark up if you want to go that route too. I don't have the used washers as I reused them on the stainless chromed set I bought from Norbo.
PostPosted: Wed Aug 15, 2018 7:43 pm
Online
Hey thanks alot guys, I have sourced everything except the cdi! Jetta90 thank you! Evans, I just ordered the ffp valves, gonna send this top end to chuck for him to do his magic! It's a 31k engine, I'm not sure if that matters to a tuner like chuck but I here they're pepper! Yammagamma away!
PostPosted: Wed Aug 15, 2018 8:17 pm
Chuck Q is the best! He'll know just how to clearance/ index the FPP billet PVs as he did mine. You'll have the best of both worlds with the YammaGamma. What was wrong with the RGV mill?
PostPosted: Wed Aug 15, 2018 8:38 pm
Online
Nothing, it screams, it's really fun actually, but it just doesn't have the out right power that a 350 has. Bear in mind this is a rg250w, not a rgv. It only has like 30-35 hp at the rear on a good day, the ypvs motor is gonna be insane in there, the bike only weighs 280lbs!
