Operation: RZ350N REVIVAL - Florida 1985 48H Project
Re: Operation: RZ350N REVIVAL - Florida 1985 48H Project
Nice job. Amazing how bad those scratches on the piston look, only to realize they are cosmetic and have zero effect on the function.
- TwoStrokeNut
Thanks. I have often wondered if shirt scratches had any affect on anything, but assumed that they did not. I know you normally do a lot of research on topics, so its good to hear another indication that it doesn't.
RZ project bike links: Operation: MOSQUITO CONTROL BIKE-RZ500 // Operation: RZ350 REVIVAL
'72 H1-500/'75 H1-500/'85 RZ350/'85 RZ500/'01 DR650/'01 Tiger 955/'07 FJR1300
- TwoStrokeNut
Service M35 - Compression and Leak-down Tests (Again!)...
The first test I did was a compression test. Even with the cylinders lightly oiled, I only reached 90psi on each cylinder. I was hoping for more, but maybe the rough surface of the new rings were contributing to that low number. At least it is up from the 80psi recorded earlier with the old rings. I will give it another go after the rings have a chance to break in and smooth out a bit.
Picture 609
Picture 610
Next was a leak-down test. Having all the parts handy from the last time, it was a piece of cake. The lead hose from my compression tester attached to one spark plug hole. I am able to check vacuum and pressure with this setup.
Picture 611
And here are the leak-down numbers.
Picture 612
Picture 613
Picture 614
Picture 615
Picture 616
These numbers very closely matched those from last time. I also squirted a dishsoap solution all over the leak point to check for blowing bubbles… nothing. So I’m calling it good and will be getting on with the rest of the re-assembly.
M35 Total Cost: US$0.00 (Nothing needed)
Picture 609
Picture 610
Picture 611
Picture 612
Picture 613
Picture 614
Picture 615
Picture 616
Have you done the compression test with a different gauge?
- TwoStrokeNut
I do not have another compression tester to verify readings. But if you recall, I earlier compared the compression tester gauge to another gauge (and my regulated air gauge) by hooking them directly to my shop air compressor and readings seem to be fairly accurate.silverstrom wrote: ↑Fri Jul 31, 2020 10:26 pm Have you done the compression test with a different gauge?
I guess there is still a chance of a leak in my quick disconnect fitting, and that could explain low readings here and some/all of loss in the leak-down test.
Maybe its time to invest in a good compression tester.
Picture 339
- TwoStrokeNut
Service M36 - Install new clutch springs...
Since the transmission had already been flushed with new oil after the cases were split and the new Motul oil only had 13 miles on it, I decided to capture and recycle it during this drain and refill. I feel pretty confident I didn’t introduce any extra dirt in it while draining.
Picture 617
I wanted to get some hard measurement on the improvement, so I rigged up a way to measure clutch lever pull lever using my luggage scale.
Picture 618
Enough though they were new springs, I wanted to measure them.
Picture 619
I’m not sure it’s necessary, but I thought it would be a good idea to pair up matching lengths and install them across from each other for best balancing of force.
Picture 620
They all are at the upper end of the range.
Picture 621
Without disturbing the oil supply and pressure lines, I was able to carefully swing the clutch cover out of the way long enough to swap out the springs. Coolant was already drained during the piston ring swap.
Picture 622
A closer look.
Picture 623
I replaced the springs in pairs and found leaving the new ones about .25” from seated to signify which ones had already been replaced. Once all six new springs were installed, I tightened them up.
Picture 624
Time for a final lever pull test and I got 5.26 pounds this time. An increase from 4.50 pounds to 5.26 doesn’t seem like much, but it represents a 17% increase, and hopefully enough to keep it from slipping during that 3 to 4th gear full power upshift.
Picture 625
M36 Total Cost: US$38.46 (Clutch springs)
Picture 617
Picture 618
Picture 619
Picture 620
Picture 621
Picture 622
A closer look.
Picture 623
Picture 624
Picture 625
Good work. Most clutch slipping problems stem from weak springs. If you measure the plates you will often find them to be fine. i measured all the plates Id saved, had come out of engines i bought and ones i got with purchases in boxes of bits - quite a lot of full clutch packs, ie 10+. And.... {drumroll}... 90% of them were fine, but all the springs (yes ALL) were useless.
- Redline Junkie
Great section on the clutch! I need to pull mine apart too, as I get some slippage under WOT sometimes. I have a new set of EBC springs in the shop I might install. I will be checking my pull force too before and after!
1987 RZ350 Stock
1985 RZ350F basket case
1985 RZ500 Stock
1987 RZ350 Stock
1985 RZ500 Stock
- TwoStrokeNut
Thanks. My observation agrees with yours... My original plates measured on the high side for thickness but the springs were on the low side. I believe you suggested replacing the springs last time I had it apart, but I didn't have any on hand at the time and I was anxious to get the engine back together. So the old ones went back in, unfortunately, and proved to be weak.JonW wrote: ↑Sun Aug 02, 2020 8:58 pm Good work. Most clutch slipping problems stem from weak springs. If you measure the plates you will often find them to be fine. i measured all the plates Id saved, had come out of engines i bought and ones i got with purchases in boxes of bits - quite a lot of full clutch packs, ie 10+. And.... {drumroll}... 90% of them were fine, but all the springs (yes ALL) were useless.
In the back of my mind, I knew this engine was coming back apart, and here I am, see the inside of this engine again for some upgrades. Luckily, it is proving to be a very simple job that didn't cost any more than the spring cost now, so no harm done. Even the clutch cover gasket was reusable.
Thanks for you continued and informative input!
- TwoStrokeNut
You probably have a similar situation to what I had... A hint of slippage at WOT. I have not reported it here yet officially, but the new OEM springs seemed to have solved my slippage issue completely. Don't quote me on it, but I seem to recall that EBC springs are a bit stiffer than OEM, and if so, that would help even more. Good luck to you. I would be interested to see what pull force you record. Thanks for chiming in.Redline Junkie wrote: ↑Mon Aug 03, 2020 7:43 am Great section on the clutch! I need to pull mine apart too, as I get some slippage under WOT sometimes. I have a new set of EBC springs in the shop I might install. I will be checking my pull force too before and after!
I found that I wouldn't have slippage with the stock springs, but if I put so much as 1/4lb pressure on the clutch lever,it would slip. I installed 3 heavy duty springs (from Tusk) and 3 stock springs. Clutch pull feels about the same, and it's no longer on the edge of friction.
- TwoStrokeNut
I think this is a great approach to the issue. Although I believe my full power slippage problem is gone with the new OEM springs, I agree that even a strong headwind pushing on that lever can start disengaging the clutch (okay, I'm exaggerating a little, actually maybe a lot), but I do know what you mean. The lever pull on this bike is really light so I wouldn't mind it being stronger to closer match my other bikes.kobra wrote: ↑Tue Aug 04, 2020 3:01 am I found that I wouldn't have slippage with the stock springs, but if I put so much as 1/4lb pressure on the clutch lever,it would slip. I installed 3 heavy duty springs (from Tusk) and 3 stock springs. Clutch pull feels about the same, and it's no longer on the edge of friction.
Since I plan to keep the bike for a long time, and knowing springs lose their spring over time, I'm sure I will be re-visiting this issue again someday.
- TwoStrokeNut
Service M37 - Install larger main jets (Mikuni VM4/042/260)...
Before the carbs went back on, I wanted to increase the main jet size just a bit. It has always ran fine with the 240’s in, but I have been warned about running lean with aftermarket chambers.
Picture 626
So 260’s went in.
Picture 627
Picture 628
Are 260’s still too small? Maybe, I don’t know… I’m no tuner. I will order some 280’s for the next time the carbs come off and we will see.
M37 Total Cost: US$15.90 (Main jets)
Picture 626
So 260’s went in.
Picture 627
Picture 628
- TwoStrokeNut
Service M38 - Install cooler spark plugs (NGK BR9ES)...
After reading about Kobra’s misfortunes on his newly rebuilt engine (still sorry to hear about that), I decided to go back to a cooler spark plug. This and slightly larger main jets should cool combustion temps down somewhat, I would hope.
Here are the BR8ES’s that came out. I am holding them respective to the side they came out of with the bike behind them. Again, I’m not a tuner, but it appears the right side cylinder has been running rich. Even when I pulled the bike out of storage and looked in the exhaust ports, I remember the right side having more carbon build-up. Is there any explanation for this?
Picture 629
BR9ES’s are going in.
Picture 630
I don’t remember the 9’s ever giving me any issues in the past, and I used to ride it quite a bit in the early 2000’s.
M38 Total Cost: US$5.84 (Plugs)
Picture 629
Picture 630
- TwoStrokeNut
Service M39 - Replace coolant...
Since I hope to not tear this engine apart again for a while, it’s time to put the final coolant in. I don’t know if there is a huge difference in coolants, but I chose Maxima Coolanol because it is readily available, is an ethylene based glycol, safe for aluminum and magnesium, and the other characteristics sound pretty good. I know I’m paying extra for the premix 50/50 blend, but these bikes don’t use much of it anyway. I always mix my own for the cars that take 3 and 4 gallons though.
Picture 631
M39 Total Cost: US$8.00 (Coolant)
Picture 631
