83 RZ350 hybrid
Re: 83 RZ350 hybrid
Found a bit of time to to start pricing this bike back together.the Master cylinder I’m using didn’t clear the Tarozzi rearset so I had to remove a small amount of material from the back side of the right rearset to clear it. Got a few other bits buttoned up and the bike and test fitted the shearer pipes.
- 090DD796-D874-4869-8DF5-F3ABBC383BC5.jpeg (131.19 KiB) Viewed 2100 times
Re: 83 RZ350 hybrid
The pipes look great, I like the line of them, Nice sweep on them, Matches the lines of the bike...
Re: 83 RZ350 hybrid
On a side note, Thats a lot of white crap you have on the ground :P
Re: 83 RZ350 hybrid
Test fitting the body work to apply the decals and get them straight as possible
- 1BCD59E3-908B-4F6D-8584-C050890F79D4.jpeg (131.44 KiB) Viewed 2066 times
- A2D99574-9AD3-480D-AE98-77A0EDAD29F5.jpeg (141.44 KiB) Viewed 2066 times
Re: 83 RZ350 hybrid
- 1188CF9D-4987-466F-9158-4E41357FBBD5.jpeg (166.82 KiB) Viewed 2064 times
Re: 83 RZ350 hybrid
Getting close. Probably pull the engine one more time. Got a billet water pump, new water pump bearing. And a couple of new slugs to stick in the cylinders still and going to put new power valve seals in well I’m at it.
- 78061240-84F8-4572-98FC-5EF9416FBD77.jpeg (185.08 KiB) Viewed 2025 times
Re: 83 RZ350 hybrid
Check if your kickstart hits the Tarozzi rearset peg when kicked. some people have had issues. There is a fix.
Where in Ontario are you? Looks like farm country. Is that an El Camino? My father had a few. I have a 70 Nova.
79 RD400F Daytona Special
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
Re: 83 RZ350 hybrid
I’m near Sauble beach.
My after market kickstart won’t work with the Tarozzi rearset a but oem clears.
It’s a 68 el Camino it’s my old mans. Had to use his shop for the heat to do the decals. My shed is to cold.
Re: 83 RZ350 hybrid
Put a new clutch kit in on Sunday, already had a brand new billet clutch basket. Got the hi flow water pump and new water pump bearing and seal installed too.
- 0084E866-F2E0-480F-93E2-CCED74482D12.jpeg (137.03 KiB) Viewed 1959 times
- Yellow and Black RZ
Re: 83 RZ350 hybrid
Not a lot left to do. Found some time last week to tidy up some minor things to do with the rearsets and brakes, got the cooling system all back on. I need to find some time to get the wiring harness back on and it’s ready to be fired up.
Hopefully in the next couple weeks it’ll be smoking again
Re: 83 RZ350 hybrid
She lives again
- 1FDF925F-DB1E-490E-B3C7-F57CEA2E940E.jpeg (218.67 KiB) Viewed 1807 times
- 9927C357-C402-4887-BAB2-116BE5945C49.jpeg (106.5 KiB) Viewed 1807 times
Re: 83 RZ350 hybrid
Very nice, Job well done, Loving the yellow paint,,
- Evans Ward
Re: 83 RZ350 hybrid
Smokin’ is good! Good job.
