Integrated Brakelight + Turnsignals
Has anyone created an integrated tail light with turn signals built into it? I was thinking of a clear tail-light housing with a LED panel for the lights.
85 RZ350-Messed up wiring
Re: Integrated Brakelight + Turnsignals
I bought a little electronic box that basically does that. It uses the stock dual filament bulbs and makes them function as Signals, tail and stop lights. They have been that way for about 15 years and the label is worn off, but you should be able to find something similar on line. If you want LED's CustomLED makes them for newer bikes and I believe sells parts to do your own. Be forewarned that the signals will not work with LEDs due to the way Yamaha wired the gauge cluster and you will need to add diodes, which CustomLED also sells. https://www.customled.com/
Mine is kind of like this; https://www.motosport.com/yana-shiki-ta ... -X001-Y001
