Stator connectors and pins
kpke
#1 Post by kpke » Sun Apr 11, 2021 12:10 am
I went for a ride today but not far due to no charging. Rode home and started troubleshooting. 2 of the 3 white wires from the stator are broken at the 4 pin connector on the harness side. I pulled all the wires out of the harness and replaced them.
Does the pinout matter for these 3 white wires? Can any of the 3 white wires mate up with the 3 white wires at the 6 pin connector going into the rectifier? They are AC going into the rectifier, are they phased in any way?
Has anyone sourced these 4 pin connectors and pins? Really I only need the pins. None of my vintage connections pins match these pins. If I can’t find replacements I will have to change it out to a different connector on both ends. But this would change the stator cable connector and if I ever replaced the stator in the future the factory connector wouldn’t work, it would have to be changed to mate with the change I make in the harness.
Re: Stator connectors and pins
#2 Post by JonW » Sun Apr 11, 2021 4:41 am
any wire can be connected to any other white.
Ive seen the connectors for sale, but dont have a link sorry.
kpke
#3 Post by kpke » Sun Apr 11, 2021 11:12 am
Thank you Jon. I figured as much on the white wires.
Anyone else have a source for these connectors and/or pins?
RZed
#4 Post by RZed » Mon Apr 12, 2021 7:54 pm
99 R1 USD front end
Tarrozi Hi-rise clipons
VJ23 swingarm
JL GP stainless pipes
2018 XSR 900
kpke
#5 Post by kpke » Tue Apr 13, 2021 8:49 am
Thanks Charlie. I'm still not finding that particular connector/pins.
I went ahead and swapped out both ends with a standard vintage connections 4 pin.
Back on the road!
