So I fired my RZ up after a top end rebuild and a carb rebuild...starts and runs, albeit doughy but have air puffing out the exhaust which would indicate a misfire or the like. Checked the sparks on the plugs and must say they look very weak and the plugs are wet...as always I didn’t touch or go near the coil but these things can sometimes happen for no reason. The bike was fine before rebuild
I just want to triple check though, the breather line from the tank goes to the RH side carb yeah??
83 RZ350 first startup
Re: 83 RZ350 first startup
Silverstrom is correct. The breather just vents to atmosphere under the seat.
89 Canadian Spec RD-350
2013 BMW R1200RT
2007 Harley XL1200C Sportster
2008 Ducati 1098R
2015 Gas Gas 300 Trials bike
1972 Turbo-Charged 240Z
Zastava Black Arrow .50 BMG
2013 BMW R1200RT
2008 Ducati 1098R
Pretty sure it goes there on RH side carb vent - one near choke balance pipe
My RZs are 49-state models, so they don't have vent hoses, but the petcock vacuum hose certainly connects to the right side carb. And I'm just spitballing here, but how would connecting a vent to another vent work?
