Did this yesterday to nail down a half-throttle hesitation:
I learned two things: it’s actually a quarter-throttle hesitation, and I ride like my grandma.
Unbelievable how little throttle I actually use. Most of the time, it’s just above idle and rarely did I ever see more than half throttle. The marks are a tuning revelation, but they’re maybe a bit more reality than I was prepared for!
Jetting 101
Jetting 101
Re: Jetting 101
You have to ride it like a 2 stroke. That means plenty of throttle most of the time. I'm not saying you need to run in the red zone all the time, but there should be no reason to be much under 6000 RPM unless you are planning to stop or slow down for traffic. Ride it like a 2 stroke and see if your throttle issues are real. Riding around at 1/4 throttle and using only the pilot circuit will just frustrate you.
The image below will show you how throttle position corresponds to the various carburetor circuits. Once you understand the correlation it will be easier for you to diagnose any part of the range that you are not happy with.
Re: Jetting 101
Boyesen has a chart that shows this same information in a different form. I've tried to insert it here, but for some reason I'm having no luck, but it can be viewed here:
https://www.treatland.tv/boyesen-dual-s ... ds-674.htm
The chart shows how the different elements you listed above overlap. I have an ancient paperback book on carburetor tuning that I still consider the Bible of Carbs.
89 Canadian Spec RD-350
2013 BMW R1200RT
2007 Harley XL1200C Sportster
2008 Ducati 1098R
2015 Gas Gas 300 Trials bike
1972 Turbo-Charged 240Z
Zastava Black Arrow .50 BMG
2013 BMW R1200RT
2008 Ducati 1098R
Re: Jetting 101
Yes, when I felt the hesitation (which is relatively new) I was thinking about worn needles as a possible cause, but I probably just need to make sure the pilots are clear and make an airscrew adjustment.
I was surprised to be rolling along at 5500 and the throttle just cracked open, maybe 1/8 throttle. All these years my wrist has been sending bad intel to my brain.
Re: Jetting 101
My wrist has been guilty, too. Heading into a WFO corner and my brain telling my wrist to hold it open. The wrist answers back, "No, no, if I do we'll all die!"
2013 BMW R1200RT
2008 Ducati 1098R
2013 BMW R1200RT
2008 Ducati 1098R
