Mid Range Issues between 5000 - 6500rpm
I wonder if you could shed any light on my mid range issue. My engine really bogs down and struggles between 5000-6500rpm. It idles perfectly and is smooth up until @5000rpm. From 6500rpm on and into the powerband, it screams and pulls all the way to 9000rpm. I have rebuilt the carbs. Cleaned behind the brass balls. Jetted it correctly (I have small can Microns and a stock air box). I also added a set of NK Racing reed valve spacers (6mm) Any air mixture recommendations? Any input or advice would be really appreciated.
Re: Mid Range Issues between 5000 - 6500rpm
Ohhhhh. The small can microns might be the problem. Notoriously well known for that exact problem.
I have a set on an LC and have much the same problem.
You could play with the needles and see if it helps. Maybe raise a notch and go from there.
Thanks @tacky1! This was the exact feedback I was looking for (to make sure I'm not completely out to lunch). I will adjust the needle and post a follow up. Cheers!
Paul...I have a set of small can micron pipes here that I was planning to use on an 88 RZ350 motor. Should I expect similar issues as the LC experienced?
I think it was the LC that had the problems John. The pv didn’t seem to have the problem. Probably due to the pv having the pvs and better porting.
Update, I lifted the needles by one slot as per Tacky1's recommendation. It made it slightly worse. I've done additional reading on the RD Crazy forum and per Tacky1's post this is a problem for small can Microns on RD's. Some people have done extensive work to try and make them work flawlessly. I am siding on putting back the stock pipes. I'll play with it a bit more and let you guys know what option I decided on. Cheers.
LC's commonly have a flat spot issue Micron pipes are not the cause.
Mine (1ua engine ) Does Not have the /a stumble issue.. Anywhere .
It revs perfectly cleanly to the 9500 limiter setting ... always has.
Look to your setup ?? If it's capably set, the pipes won't create any issues.. Whatsoever.
I entirely eliminated the midrange flat spot on my LC (stock pipes w loud inserts) just by installing a set of 6mm reed spacers. However I note the OP has already installed reed spacers.
I fired an old set of pipes on to my LC and the flat spot was practically gone. It’s deffo a known prob on the LC with microns. I put the microns back on. I’ll just have to live with it
