How to test if your fuel cap is venting proper
LC Cnd
#1 Post by LC Cnd » Fri Jun 18, 2021 3:00 am
Here is a simple way to test to eliminate if your fuel cap is the cause of a performance issue. I will be using a 20L jerry can to conduct the test.
https://youtu.be/4Hk4eXL_qIU
kpke
Re: How to test if your fuel cap is venting proper
#2 Post by kpke » Fri Jun 18, 2021 9:30 am
:smt023 Let us know how your test goes.
LC Cnd
#3 Post by LC Cnd » Mon Jun 21, 2021 2:21 am
The test worked well testing two standard fuel caps in approximately 15 minutes. Use reserve setting to drain. The flow was steady on both tests on 2 full tanks via the right side fuel line.
