Hello. Just finished my Roberts edition restoration. My bike has the RD Y tube single air filter, Tommie exhaust, and Force V-tec reeds.
The bike is running, to me at least extremely rich. Main is a #420 and pilot #25. A heavy smoker and the plugs are very wet. Just ran it once to operating temp then shut her down.
I have some 2 stroke dirt bike tuning experience but the rz-350 is new to me. Thanks
Jetting. Good place to start question.
1984 Yamaha RZ-350 Roberts edition
2019 Yamaha FJR-1300
2015 Yamaha R-3
2007 Honda 954rr
2004 Honda RC-51 Nicky Hayden edition
2018 KTM 500-EXC
2010 HD Ultra Classic
Special Construction Pro Street
2015 300cti Vespa
2015 Yamaha R-3
2007 Honda 954rr
2018 KTM 500-EXC
2015 300cti Vespa
Re: Jetting. Good place to start question.
This is what Toomey recommends (and sells, of course) for his pipes. The main isn't doing anything when you're just bringing the bike up to temp, if you're running rich while idling look to the pilot circuit, and pay particular attention to your float setting.
SPECIAL NEEDLES AND MAIN JETS GROUND SPECIFICALLY FOR THE STOCK CARBS OF THE US MODEL RZ. NOMINAL SETTING IS NEEDLE ON THE THIRD GROOVE, #410 MAIN JET STD FLOAT SETTING (21MM +/- 1) STOCK #20 PILOT JET, PILOT AIR SCREW SET AT .5 TURNS OUT (1/2 TURN OUT)
89 Canadian Spec RD-350
2013 BMW R1200RT
2007 Harley XL1200C Sportster
2008 Ducati 1098R
2015 Gas Gas 300 Trials bike
1972 Turbo-Charged 240Z
Zastava Black Arrow .50 BMG
2013 BMW R1200RT
2008 Ducati 1098R
Thanks for the reply, Darrell. Ran the motor a little harder today, after warm-up. Sounds great, nice and crisp on the throttle response, still quite the smoker even in the higher RPMs. Will follow up on the Toomey recommendations. #230 jump to #410 just seems excessive, what do I know. Not much about tunning this motor.
2015 Yamaha R-3
2007 Honda 954rr
2018 KTM 500-EXC
2015 300cti Vespa
2015 Yamaha R-3
2007 Honda 954rr
2018 KTM 500-EXC
2015 300cti Vespa
