crank bearing instal
We love ALL motorcycles - post your non-2T custom build here!
two-stroke-brit
Post by two-stroke-brit »
Well i have a 98 kdx 220r that i am rebuilding.
needed crank seals and bearings as well as a host of other issues( beat to near death ).
have it all apart and replaced the bearings in the cases and slid the crank in one side ,
went to put the other case on and NO GO.
checked things that could be hanging it up all looks good.
finally measured the bearing and its 0.01 mm small .
now i checked both bearings i removed and they are -.005 mm at most small.
i had the crank in the freezer and the cases in the texas noon day sun ( too hot for bare hands).
before i reorder another and hope for a bigger bore.
any ideas i am reluctant to directly heat the bearing as the rubber crank seal is right there.
T I A
cheers mark.
Re: crank bearing instal
Post by JonW »
Wow interesting, these were bearings supplied by Kawasaki Mark?
(loved the KDX's back in the day... had a mid 90s 250SR but the 220 was a much better bike really for off road, the 250 was a flyer with the Boysens drilled apparently as its a detuned KZ motor really, I never drilled mine and its was more than fast enough as it was lol)
85RZwade
Post by 85RZwade »
It's gotta be the wrong bearing, doesn't it? Production tolerances are pretty consistent with bearings, right? Either way, I'd be going after another new bearing for that side.
two-stroke-brit
JonW wrote: Mon Aug 16, 2021 10:30 pm Wow interesting, these were bearings supplied by Kawasaki Mark?
yep i got them from a kawi jetski place.
mark
two-stroke-brit
Thanks all, i will reorder a replacement.
cheers mark
Post by JonW »
Very strange :/
two-stroke-brit
watched a video on a guy using a socket heated up with a torch then placing the socket in the inner race to transfer the heat and was able to install the bearing on and off for a good minute.
i will turn up a heat sink out of copper and try this.
cheers mark
