Headlight lens options for US Spec RZ350?
Evans Ward
#1 Post by Evans Ward » Thu Aug 25, 2022 12:29 pm
The glass headlight lens on my 1984 RZ350 with the seat made on to the lens is fubared so that the spring will not stay seated. Both side tangs are broken off. :smt022 Without it seating, the lens can not be stabilized. I ordered a new original glass lens from partzilla (expensive!) but received a follow up email from them that this part is on back order with no known ETA. Since there is no telling how long that might take to receive the part, I’m looking at lower cost alternatives that will bolt up in the stock HL bucket using both the chrome inner ring and larger outer ring. I’ve heard that the RD250LC/ RD350LC using the same size and look but I see that it uses 3 spring clips internally. Can anyone verify that the Elsie glass lens will work on a US Spec 84-5 RZ350? :smt017 Are there any other glass lens bolt on alternatives/ options? Aftermarket is fine as long as it has a somewhat stock appearance. I can’t believe the prices of used RZ350 glass lenses on eBay!! $125-$350!! :smt014 Thanks in advance for any and all help and suggestions! :smt001
kpke
Re: Headlight lens options for US Spec RZ350?
#2 Post by kpke » Fri Aug 26, 2022 9:15 am
Hi Evans. If you just need the glass headlight, send me an email. I have several used spares. :smt045
Evans Ward
#3 Post by Evans Ward » Fri Aug 26, 2022 1:27 pm
kpke wrote: Fri Aug 26, 2022 9:15 am Hi Evans. If you just need the glass headlight, send me an email. I have several used spares. :smt045
Hi Ken,
I sent you a PM here on this site as I can’t find your email address. Thank you kind sir! :smt001
Evans Ward
#4 Post by Evans Ward » Wed Aug 31, 2022 9:37 am
Ken is hooking me up. He could be my brother from another mother! 🤔 A good man he is!!👍
