Brass Balls
Brass Balls
Decided to clean behind the brass ball passageways of the VM26's. Tapped the top of the ball with a nail and drilled out with a 3/64" bit. Reversed the bit, into the drilled hole, to pop out the ball(s). Bought a pair of 10-24x3/16 scrub screws at 17 cents a piece from Lordco as replacements. The scrub screws easily self tapped into the hole for future inspection. Hoped to used brass scrubs but steel was all that was available - worked well.
- IMG_5049.JPG (19.44 KiB) Viewed 543 times
- IMG_5050.JPG (22.94 KiB) Viewed 543 times
- IMG_5053.JPG (25.8 KiB) Viewed 543 times
Re: Brass Balls
I’ve been told often that I have a set…
Re: Brass Balls
Well if your going to do Mad Sunday (although I hear it's become rather pedestrian sadly) you might need em lol.
