Rear fender elimination kits for RZ350?
- Evans Ward
In a search of ye old ‘innerwebs, I found 2 different rear fender elimination kits for our bikes both out of Japan. One is made by Coerce and the other produced by ACP in the range of $110-$150 not including shipping. Has anyone used either or know of any vendor that may have a different one? I’m looking for a molested/ cut rear fender to use with my solo cowl and have a WTB post here. I have a 1984 US Spec RZ350. In case that I can’t find a previously cut rear fender piece, I may look into purchase of a rear fender elimination kit. I’m not skilled enough to make one myself and I don’t know of any other model that may interchange?
Re: Rear fender elimination kits for RZ350?
Got a link for those fender kits Evans?
Ken's Garage
- Evans Ward
Here ya go Ken:
https://japan.webike.net/products/17693 ... Vg3D3g39Ig
https://japan.webike.net/products/20899 ... xjEALw_wcB
In case you are not aware, those pictures show the earlier LC model (80-82), the non-YPVS RD350, which is completely different frame/fender wise.
I think they might call it a RZ in Japan, hence the confusion.
RD350YPVS LC2
- Evans Ward
Thanks for that info- I thought they looked different. Did Japan get a model like the US Spec; and if so, would you happen to know the official designation?
It's complicated. I'm afraid the only answer is to research until you know everything.
It also depends on the country. In the UK we call them:
LC - 4LO the original water cooled RD350. I don't think this was sold in north America?
LC2 - The first YPVS. The 31k bikini fairing model. A completely revised bike with very little interchangeable with the LC.
F1/N1 - A revised YPVS, mostly the same 31k part number but with some minor differences, plus fairing (F) or naked (N).
F2/N2 - A further revision of the YPVS. 1UA, some bigger differences to the frame, tank and plastics.
R - The last Brazil built YPVS twin headlight model.
RD350YPVS LC2
The RDLCcrazy website has a brief history of the different models:
https://rdlccrazy.co.uk/
RD350YPVS LC2
