[b]Anyone interested ??[/b]
I am putting my project up for sale. If anyone is interested please contact me at jbuanno@gmail.com. I can fill you in on all the details. I am asking 2000.00. I know i could probably rip it apart and ebay it but if someone is interested in it whole.....
1990 GSXR 750 front end, FZ600 swingarm FZR400 rear rim (no machining, i used the offset front sprocket) 1999 R1 bodywork ( also have the lower) FOX Twin CLicker shock rebuilt with new style gas reservoir, sprung for 175-180 lb. rider.
I put a cheetah cub cylinder on this spring. It has a wiseco long rod stroker crank @4mm with a 65 mm bore for 385 cc. It has no spacer, it uses a .060 base gasket. It has a stock banshee head cut .020, (I used VP C-12 and MAxima 927 @ 24:1 the one race weekend the motor has on it.) The cylinder was bought from Vito's, a banshee shop. I also fabricated a thermostat sytem from an FZR400. The carbs are Lectron 36/34 HI-VO in stock manifolds with TDR fiber reeds.
This engine NEEDS a custom set of pipes fabricated. The ones on it do not work for this engine, the powerband is way too narrow. It also needs a larger capacity radiator. I am being honest here, you will have to monkey with it a little but a lot of the work has been done. I also fabricated the rearsets from a 1990 GSXR 750. This is a racebike, to street it you would need a wiring harness, i chopped this one up. I have more pictures available.
john buanno
www.speedbike.com
www.speedbike.com
Where you been?
Hey Biz, haven't heard from you in a while. Still at the same email addy?Let me know if you're going out to check out Johns bike, maybe we can hook up, I'm pretty close to Enfield.
Peter
Peter
http://www.putfile.com/jbuanno/images/123487
anyone interested in this thing? i need cash in a hurry, if someone brings me 1400.00 by Friday, its yours...it has been in my basement since this thread started last summer, same status. you can tear it apart and ebay everything for a profit.. If it doesnt go by friday as a unit, start looking on ebay for parts......
john buanno
www.speedbike.com
www.speedbike.com
