racebike progression
- alexanderdraper
this is what she looked like the day i bought her. that was in 04' i think.
a year later.
last year. have since soled those spec 2's
not much different visually from the 2nd photo except for the pipes.
but due to an oil line coming loose there were a few of engine mods done.
-4mm stroker crank.
-base plate spacer
-porting
-combustion chamber reshaping/cc'ing
-32mm vm carbs
-mossemburge 6 petal reeds
there are a few more things in the works as far as mods.
i plan on racing it in a vintage series here in ontario (the VRRA)
so i have a lot of prep work to do.
i just got JL pipes the other day as well as new clipons, ss brake lines, a solo tail section, steering damper, completely rebuilt forks with race tech emulators and more stuff that i can't think of right now.
will post pics as i get more completed.
a year later.
-4mm stroker crank.
-base plate spacer
-porting
-32mm vm carbs
Last edited by alexanderdraper on Mon Feb 18, 2013 11:17 pm, edited 1 time in total.
Porting&pipes by GPL racing, hotrods 4mm crank,
mikuni36mmTM, zeel ignition, V-Force4, gusseted 86frame, Fz600 swingarm, 89gsxr750 wheels&brakes, Elka shock, fzr600 forks with r6 internals fitted by accelerated tech
Oooh JL those are the shit bro, If you can, send us some sound bites when it is done.
- alexanderdraper
maybe it was your bike.
were you the one that crashed it? cuz it sure was laid down hard at some point.
- alexanderdraper
here are a couple pics of the latest iteration of my old girl.
not much left to do on her. just a couple more small odds and ends to finish up before we go racing next weekend!
- alexanderdraper
- aaronmvrider
very nice love those pipes are they a set of gp exit pipes or are they called high risers ??? will look nice with a single seat....
i am planning to strip my 350 next year and freshen her up internally, although she still goes like a scalded cat on speed, what sort of hp numbers are you getting out of your set up
Aaron
Aaron
1 x 4mm stroker rz 375cc 1983
1 x rz 500
1 x mv agusta 1000
1 x rz 500
1 x mv agusta 1000
- aaronmvrider
- alexanderdraper
ya those are the GP exit ones. i dunno what kinda hp shes got i have no access to a dyno.
i cant get a fork brace for her because none makes/made on for the forks that are on it.
i'm running avons. am23 90/90 on the front and an avon super venom 120/80 on the rear.
i don't think that it is the same bike. the shade of yellow is different.
- alexanderdraper
it was my sister's video camera sooo.. that probabl would have been a good idea!nokturnal wrote:hold the cam button down half way to auto focus, then press the rest of the way to take the pic.
next time.
i took a video but managed to loose it in the process of taking it off the cam.
- alexanderdraper
had a race over the weekend. did well in the heat race but had an off in the final. corner 2 at Mosport is kind of notorious around here. its a crazy blind 5 story drop into a double apex, decreasing radius, off-camber left hander.
i turned in too early and was going too fast ending in me going wide into the grass going at least 100 mph.
i waled away with a head ache and a broken pinky-finger.
here is what the 86 looks like
