racebike progression
Re: racebike progression
11MM is right.
Tim Steele in Front Royal, VA
- alexanderdraper
to race in my club (VRRA) the parts need to be like what was used in the period one is racing (p4 in my case)
unfortunately the blue pot r6 calipers have been deemed to be out of period.
that being said does anyone know of a caliper that will work on the r6 forks with the r6 wheel?
Porting&pipes by GPL racing, hotrods 4mm crank,
mikuni36mmTM, zeel ignition, V-Force4, gusseted 86frame, Fz600 swingarm, 89gsxr750 wheels&brakes, Elka shock, fzr600 forks with r6 internals fitted by accelerated tech
- alexanderdraper
I'm not sure, but I'd look for older bikes in the Yamaha range, with a earlier design of a four pot caliper. Many of them are 'upgraded' to the blue spots, so we know the mounting holes must be the same. The TRX850 or FZR600 for example. There may be differences in the position of bleed nipples, or size of the pistons to consider.
RD350YPVS LC2
- alexanderdraper
hummmm i already have a set of fzr 600 calipers in a box somewhere. heres to hoping they will fit
A quick look online seems to show that a similar caliper was used on lots of different Yamaha models and that the piston diameter is 34mm.
https://titanclassics.com/product/front ... build-kit/
With 34mm pistons you'd probably want a slightly bigger master cylinder than 11mm, because the total piston area is greater than for the blue spots. Probably somewhere between 12mm and 15mm. I'd aim for 12.7 (1/2") to start with.
RD350YPVS LC2
