Solo cowl
slow86gn
Solo cowl
#1 Post by slow86gn » Sat Jun 02, 2012 7:44 pm
How does it attach? I know there are brackets that mount to the seat. Is there a bracket on the back? Anyone have pictures? Thanks John
1985 RZ350NC. 1979 RD 400 Dayton Special 2015 KTM 690 DUKE
BrianT
#2 Post by BrianT » Sun Jun 03, 2012 8:39 am
The Yamaha cowl attaches at the rear using two 32mmx3.4mm O rings. They go around the turn signal stalks and go up and over the tabs that are on the back of the cowl. You can see it just to the right of my tail light.
They were a little tight getting on the first time. But I had them off yesterday to fill my oil tank and they went back on fairly easily.
1984 RZ350L
Many thanks to www.WilsonPerformance.net !!!
Evans Ward
#3 Post by Evans Ward » Sun Jun 03, 2012 9:06 am
The seat brackets provide the main system of support for the solo seat cowl. 2 screws for the bracket through seat side to the seat latch screw points and 2 screws to secure cowl to upper bracket attachment that are hidden by the small butt cushion seat piece. The O rings keep the rear of the piece secure from flopping around vertically but it won't move too far if one or both O rings come off. For the O ring attachments, there are inner tabs glassed to the inside of the cowl (both sides) where the O ring loops too. The other end is seen in Brian's above picture arouund turn signal mounts. Thanks for posting the size needed Brain on the rubber O ring as I have one that is too tight and keeps coming/ slipping off. You have a beautiful bike too BTW and it turned out spectacularly! :smt007
BrianT
#4 Post by BrianT » Sun Jun 03, 2012 9:21 am
Thanks Evans! We are pretty happy with the work so far.
Here's a little tid bit that I didn't put in my build thread. My cowl had some work done to it at one time or another. The holes behind the pad had been partially filled with putty. You could kind of see where they had been but not really. When we went to mount it up, there was no way to see where the bracket and it's hole were because they were hidden behind the cowl, but we could tell that they weren't even close. Solution? We stuck a couple of plastic zip ties through the holes, went through the mounting brackets and cynched them down tight. They are hidden by the pad, so you can't see them and they aren't going anywhere.
Someday I MIGHT get the balls to start drilling holes in my cowl, but not anytime soon!!
1984 RZ350L
Evans Ward
#5 Post by Evans Ward » Sun Jun 03, 2012 9:47 am
Funny you mentioned that Brian. When I had my solo cowl repainted this past time, I discovered that the PO had glassed over the holes where the upper seat braket mounts to cowl. I did get up the nerve to drill new holes only after I studied as many pics as I could find on the net. Thanks Mr. Gore for your invention as the reference pics really helped! :smt006 :smt008 I was close enough to make things work and I used small rubber grommets on the allen head stainless bolts. One other thing I found in doing this was that you will need to carry the correct allen wrench with you to access the oil tank and under seat area for tools if away from your shop. What I found that works perfect is a small case will slide behind the butt cushion area on top of the seat portion not seen to place this wrench, spare O rings, etc. In my case, my youngest son's spare zippered DSI game case worked perfectly and was free from him! Thanks Will! :smt002
BrianT
#6 Post by BrianT » Sun Jun 03, 2012 11:15 am
Evans Ward wrote:One other thing I found in doing this was that you will need to carry the correct allen wrench with you to access the oil tank and under seat area for tools if away from your shop. What I found that works perfect is a small case will slide behind the butt cushion area on top of the seat portion not seen to place this wrench, spare O rings, etc. In my case, my youngest son's spare zippered DSI game case worked perfectly and was free from him! Thanks Will! :smt002
Wait. What?!? I just pop the O rings loose, and release the seat latches. My seat/cowl lifts off as one piece. I just did it last night to fill my oil tank.
1984 RZ350L
Evans Ward
#7 Post by Evans Ward » Sun Jun 03, 2012 12:10 pm
It may do as you mention Brian and I need to try that. How do you unlock and get your key out to pull out as one piece?
BrianT
#8 Post by BrianT » Sun Jun 03, 2012 12:11 pm
I have never tried the lock...yet!!!
1984 RZ350L
Evans Ward
#9 Post by Evans Ward » Sun Jun 03, 2012 12:22 pm
BrianT wrote:I have never tried the lock...yet!!!
I don't know how to use mine without unlocking the seat? Mine will not unlatch without unlocking the seat with the key in the lock. With the key in the lock, I don't see a way to take it off as one piece with the seat? :smt017
BrianT
#10 Post by BrianT » Sun Jun 03, 2012 3:58 pm
I just went and played around with mine. I can't get the seat to lock at all. :smt013 Helmet lock works fine.
1984 RZ350L
slow86gn
#11 Post by slow86gn » Sun Jun 03, 2012 10:39 pm
Thanks for the help. Those o-rings came with the cowl, I just didn't no where they went or what they were for. I guess the solo cowl and that touring box that mounts to the gas tank were accessories. No info on them in service manual. Thanks again. Later John :smt003
aaronmvrider
#12 Post by aaronmvrider » Thu Jun 21, 2012 9:10 am
found it..... :smt003 :smt003 been looking for this thread...
if anyone has there seat off... solo cover... could you take some photos of the brackets how they are secured to the tail..
how did you go with locking your seats.... my seat doesnt need a key... perhaps you have later model seats.... if i am reading this correctly....
decal kits... which company did you use...
Aaron...
:smt003 :smt003 should have mine next week.... OEM mint condition.... wrong colour :smt009 :smt009
1 x 4mm stroker rz 375cc 1983
1 x rz 500
1 x mv agusta 1000
aaronmvrider
#13 Post by aaronmvrider » Mon Jun 25, 2012 6:18 am
:smt006 :smt006 just got my solo seat....
not as good condition as described but it is intact and going to be painted ...
it came with all brackets... just need the orings.... 32mm
so will post it in my build thread when finished...paint etc..
Aaron :smt002 :smt002
1 x rz 500
1 x mv agusta 1000
#14 Post by JonW » Mon Jun 25, 2012 9:10 am
Decals for the usual source Aaron... :smt002
aaronmvrider
#15 Post by aaronmvrider » Mon Jun 25, 2012 7:09 pm
yes... decals undecided as yet...
the rear tail unit is surprisingly large.....
i have a blue european colour scheme on the tail .... i dont mind it...
may even do this bike blue ???
1 x rz 500
1 x mv agusta 1000
