It is currently Tue Jun 19, 2018 8:06 am
Post new topic Reply to topic  [ 130 posts ]  Go to page 1, 2, 3, 4, 5 ... 9  Next
PostPosted: Mon Mar 04, 2013 8:56 pm
I have pictures I want to put up for this but do not have a Photo bucket or anything like that account
if someone can tell me how to do this
Laird
PostPosted: Mon Mar 04, 2013 10:59 pm
See below
:smt017
PostPosted: Wed Mar 06, 2013 1:57 am
:smt017
PostPosted: Wed Mar 06, 2013 1:58 am
:smt017
PostPosted: Wed Mar 06, 2013 2:00 am
wow.... cant wait to see the results....
very nice work...
1 x 4mm stroker rz 375cc 1983
1 x rz 500
1 x mv agusta 1000
PostPosted: Wed Mar 06, 2013 11:49 am
:smt017
PostPosted: Wed Mar 06, 2013 1:25 pm
Thankyou so much for posting these
The Panelview on the triple tree is Allen Bradley 600Plus ---touchscreen
The ECM is infact an Allen Bradley PLC for direct air and fuel injection to run a 3Stroke/3 Stage motor design
Will be on track by this May in Ontario racetrakcs and headed to the Ulstergrand Prix and some other road races in August in Ulster/Northern Ireland
A bigger Moto2 bike is also under build at the moment
Still based on the RZ Frame ---Side shock mount and -Billet 3 piece swingarm
3 Pice billet swing arm and 3stoke/3stage motor under first stage patent USA
Thanks for looking and will up date as it progresses
Laird Shingleton
PostPosted: Wed Mar 06, 2013 6:22 pm
what engine you running in it ????
1 x rz 500
1 x mv agusta 1000
PostPosted: Wed Mar 06, 2013 6:38 pm
Started out as WR250X but only the bottom end and Cylinder/cases-------The intake valves are removed and replaced with direct air and fuel --Thus the 3 stage motor---------The Moto1 bike will be a 465 Banshee clone with modified Heads for direct air and fuel ------hope that fill in some of the blanks
PostPosted: Wed Mar 06, 2013 10:36 pm
build 3 or 4 of them.... and send them to me please
1 x rz 500
1 x mv agusta 1000
PostPosted: Thu Mar 07, 2013 8:57 pm
IF it all works as a package and proves compeditive I will build a few of them
Win on Sunday sell on Monday I still believe in
If I don't try I will never know how good it is and that's all i can do -its a totally different direction for racing and thinking of how to build and manufacture bikes
PostPosted: Fri Mar 08, 2013 9:11 am
Im liking that swing arm set up!Very interesting build!
PostPosted: Fri Mar 08, 2013 9:46 am
Interesting stuff!!
Am I right in thinking your converting a reed fed engine into direct injection? that's the way I read it.
Glyn
PostPosted: Fri Mar 08, 2013 10:46 am
Moto3 Bike
Shingleton Advanced Engineering Patent pending on Sing arm and 3 Stage motor/Stroke
Take a Four stroke single cylinder
Remove the head
Change cam gear so Exhaust and crank are one to one
Remove intack cam and repalce with one fuel and one air fed injector
3 Stage Cycle -used to be 3 stoke or 2 in 6 power stroke Motor but now revised
Stages basic descreption
Power to 45 deg
Exhaust opens
Air injection exchaning air and clearing cylinder for length of exhaust open
245 Deg exhaust closes and Direction occurs under copression
Stages completed
The Moto1 bike is the easier of the two
Bombardier with Rotax buildt a 600 etec motor for there sleds making 160 to 190 hp in race trim
The Etec motor uses a direct injection of air and fuel after the transferrs have close thus no return pulse of exhaust needed
This was developed by Optimun and Evenrude outboard by Queens Uni in Belfast in the early 2000s
For theMoto1 bike i am building a 465 Banshee ---get it up and running and then put the Etec heads on
The advantage to this is combustion chamber pressure can be changed by duration of injection --so also giving power on demand
Yes i know i am crazy but will give it a good go and that all we can do ----if i dont try i will get know were
Ps-The swing arms sides where made from billet pieces -----28 inch by 8 inch by 2 inch
Dual pressed in Wheel beairngs so no maintenance required
by Expanding the center piece you can change wheels for anysize bike
PostPosted: Fri Mar 08, 2013 12:07 pm
I don't think your crazy........................well just a little :smt002 .
I work with Evinrude and Mercury motors everyday, they are not really performance engines!!, same goes for sled motor's. I feel your end up "time limited" to make any real power above what the original motor could be tuned to produce.
Hope it all works out for ya
Glyn
