solo seat leads?
brrrappp
Re: solo seat leads?
#31 Post by brrrappp » Mon Sep 24, 2018 3:20 am
Anyone have the Solo-Seat mounting hardware and willing to sell? I seem to have lost the two brackets that came with mine. I put it away 25 years ago and unpacked it this week only- no hardware :(
#32 Post by JonW » Mon Sep 24, 2018 5:23 am
I saw some on ebay the the day actually, modern repros but defo up there but not as cheap as they used to be.
Actually, you used to be able to get them cheaply from Cruzin image on ebay so maybe he still has some if you email him as well?
brrrappp
#33 Post by brrrappp » Mon Sep 24, 2018 12:41 pm
JonW wrote:I saw some on ebay the the day actually, modern repros but defo up there but not as cheap as they used to be.
If you see them on ebay or elsewhere please share a link. I've been searching ebay with no luck. Yes, I sent a message to cruzin image hope to get a response soon.
Evans Ward
#34 Post by Evans Ward » Mon Sep 24, 2018 12:44 pm
National Fiberglass has the brackets. I believe he is glassndude on eBay. I can supply the correct size large O rings needed for the rear tabs to turn signal bracket stalk holds if needed.
brrrappp
#35 Post by brrrappp » Mon Sep 24, 2018 1:03 pm
Evans Ward wrote:National Fiberglass has the brackets. I believe he is glassndude on eBay. I can supply the correct size large O rings needed for the rear tabs to turn signal bracket stalk holds if needed.
Thanks! I sent that ebay user a note and hope to get a response. I never knew that o-rings were the preferred method of holding the very back to the turn signal stalk. Thanks for that info!
ZedSledder
#36 Post by ZedSledder » Mon Sep 24, 2018 9:25 pm
I found caliper seals worked to loop over the turn signal stems as well. Might not be the exact same size but fixed them. Those seals are expensive though so its only useful info if you’ve rebuilt your brake calipers and have the old ones still on hand. Evans would be the best bet.
#37 Post by JonW » Mon Sep 24, 2018 11:49 pm
you could just buy o rings the right size online; a bag of 50 would be cheap as chips... Its not like the solo cowl versions were anything special.
brrrappp
#38 Post by brrrappp » Tue Sep 25, 2018 8:38 pm
Cruzin image responded with a No More Left and Unknown ETA if at all.
#39 Post by JonW » Tue Sep 25, 2018 8:49 pm
They are pretty easy to make really, im sure someone could tell you sizes, its just bent metal with nuts welded on.
brrrappp
#40 Post by brrrappp » Tue Sep 25, 2018 11:16 pm
JonW wrote:They are pretty easy to make really, im sure someone could tell you sizes, its just bent metal with nuts welded on.
Thanks, if I can't find originals somewhere I will get some made. I have one set of originals to use as a pattern but I have more than 1 RZ with a matching rear solo seat. I would prefer to have them look factory.....you know how it is.
#41 Post by JonW » Wed Sep 26, 2018 12:02 am
Yes but my point is that they were low volume production items and not that well made originally, hence easy to copy. Im not suggesting a hacksaw and 10mins in the shed, Im talking about doing it properly, with a coat of paint theyd be indistinguable from the originals I reckon.
Remember these cowls might have been nice but their fixings left a lot to be desired; o rings round the indicators? Yes, really...
brrrappp
#42 Post by brrrappp » Wed Sep 26, 2018 12:40 am
So, are you saying you'll whip =-up a set for me?
#43 Post by JonW » Wed Sep 26, 2018 2:41 am
If i had the time and lived closer i would.
Srhiskx
#44 Post by Srhiskx » Wed Sep 26, 2018 6:44 pm
Try RZ’s Unlimited for the brackets. When got mine he had both originals and SS copies of them.
84 RZ350. Ed Toomy designs pipes , milled head, PWK 28mm Keihins, Y air boot/ k&n filter, VForce4’s, Zeel, Dynatec ignition coil,R6 calipers, Ohlins, sonic springs 80wt fork springs, FZ1 master cylinder.
Evans Ward
#45 Post by Evans Ward » Sat Sep 29, 2018 9:31 pm
O ring size needed for rear hold is: 42-43mm in round unstretched form.
