Yzrhybrid modern up to date build
Project finally on the way after lot sadness over last 5 years wife I’ll then passing in feb 2020.build spec -latest Sponden rolling chassis Maxton rear shock ohlins front brembo radial callipers dry Hyd clucht Athena 170 cylinder kits kiehin 38 pwk zeeltronic Ign new Cnc top case inlet ported 4 Crancases induction.carbon fibre wheels. I’ll keep you all posted as we progress just had scann result top case got to be put into sold model 3D we’re we remodel top case.then we’re have it machined .would put pictures up don’t no how to get on site if anyone can advise
Re: Yzrhybrid modern up to date build
I'm sorry for your loss. It hurts and the worlds not the same after.
So another over the top build. The Spondon chassis, gotta see it!
I use Imagur because folks here recomended. I stumbled through it pretty easy and pics come out good
It is good that you have an interest/project. I hope it helps in some way.
