ChequeredFlagRacing
#1
Post
by ChequeredFlagRacing » Thu Apr 20, 2023 3:52 pm
Best method to part them now I have all the bolts out?
Last time I did this I sealed them with the product Allen Millyard uses, Permatex ultra grey and they are now being a pain.
Shame Yamaha didn't instill some 'jacking' points so they could be jacked apart to help with separating them
![😡](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/1f621.svg)
, or did they?
https://www.amazon.co.uk/Permatex-82194 ... B000HBGI8K
Yamaha FS1E 1975
Yamaha RD200 1976
Yamaha RD400 1977
Yamaha AS3 125cc 1978
Yamaha AS1 125cc 1979
Honda CX500
Honda MT125cc 1980
Yamaha TZ125G 1981-82
Zeger TC500cc 1983-84
Yamaha RD500LC 1985-87
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Smoker
![- - - - - - - - - -](./images/ranks/contributor_grey.gif)
#2
Post
by Smoker » Thu Apr 20, 2023 5:59 pm
I don't know of any points you can use to split the crankcase, but my knowledge of this engine is weak.
I do have a lot of experience with Permatex, and stuck parts, though. Heat, and A LOT of it, will soften up that adhesive considerably.
Just trying to help. Good luck!
Jeff B
#3
Post
by Jeff B » Fri Apr 21, 2023 2:12 pm
Is there a place to put a pry bar below the front lower motor mount? I know the upper casting overhangs the lower for that motor mount.
steveho
#4
Post
by steveho » Fri Apr 21, 2023 4:14 pm
Jeff B is right. I have a motor in the house and I just took a look, and there are a couple of pry point at the front of the cases.
Alternatively, a few taps with a rawhide mallet on the crankshafts adjacent to the cases might encourage separation.
Just checked again and there is another pry point at the rear of the cases above the engine number, where the top case overhangs.
Good luck!
ChequeredFlagRacing
#5
Post
by ChequeredFlagRacing » Sun Apr 23, 2023 5:13 am
Thanks guys. Will have a look for these pry points
Will have to beg steel or borrow a rawhide mallet from my brother
Will also heat the case before starting
Yamaha FS1E 1975
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
ChequeredFlagRacing
#6
Post
by ChequeredFlagRacing » Mon Apr 24, 2023 8:52 am
DOH !!!
Happy Days, we have a separation. No not her indoors but the crankcases.
Two hours of warming and there apart and then looked for the pry points.
Just had to remove two more bolts underneath by the shock I'd missed. Bolts 13 & 14 I think the numbers are.
No crankcases were harmed with all the hammering and levering thank God.
Yamaha FS1E 1975
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
