Hello to the community. One year I haven't posted in this thread, although quite a lot have happened.
The pandemic had at least one positive effect to me: allowing to spend time on this project.
With short work and forced to stay home, I've been located in the garage quite often during the past months !
Let's follow the timeline.
Since the last post, I've installed a 520 chain and front+rear sprockets 16x42. The front sprocket comes from an older R1.
And I also installed the front brake, Nissin radial PR19 master cylinder, combined with the Yamaha blue dots calipers.
The final fuel lines are also installed, now it can run properly on its own !
I had to redo some carb work, one fuel level was wrong. Now I have no carb pissing.
The engine starts really easily, and it runs well. I'm super happy about the rebuild.
https://photos.app.goo.gl/YY5ZjWQ9BTjzRwTK8
For the rear set I've choosen to go for 750 GSX-Rs from the end of 90s.
It was a bit of a headache to find the right mounting position to have no interference between selector and side stand.
And last October I received this box from China !
A full fairing.
It's OK quality. Far from being perfect, they align quite well, and the paint is correct if you don't mind having some drippings here and there in corners.
For 350€ it is definitely worth it.
No finish inside the panels.
And then I could see her complete finally !
She's too high from the front.
I weighted her at 168kg as is (89kg front / 79kg rear), ready to run or almost. She'll weight 170kg when finished I think. Whereas the front fork is from a YZF which is more 200kg. And I'm a light rider (60kg).
The plan is to get front springs tailor made to fit this light setup.
And recently I painted the inside of the front fairing in matt black, installed the mirrors too.
My tacho doesn't work. I can see the hand slightly moving when switching on and off the engine. So it's not totally dead.
I read here and there I could try to "shake" the electronics, I'll give it a try when I can spend time at my workplace.
The engine still has a very small oil leak at the oil pump cover. I haven't tackled this yet.
It's now removed again and I'll see what I can do.
It was the opportunity to a first oil change. In total the engine has run 30 to 60 minutes I guess since the rebuilt.
The oil pump filter has collected some black glue sealant small pieces from the inside of the cranks.
