RC45's Project-OW48R/53P/TZ500J - 1985 Works Brembos!
Re: RC45's Project-YZR500/OW54 - AirTech 4 the Win!
OK, so its been a while since I spent time on this bike - sourcing the appropriate TZ500/YZR500 tail piece was the issue, and what ever I tried to cobble together with fibreglass ended up looking clumsy, clunky and home made.
Then I managed to find a TZ500J tail piece.
Build back on track.
And once again, I am having to fix the damn images - imageshack keeps losing the "reduce size" funciotn and then full size images keep showing up
CBR1000RR SP2 HRC WSBK
TZ500V/OW53 Track bike
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
TZR250 3MA Track Bike
427ci C5 Z07
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
Re: RC45's Project-YZR500/OW54 - TZ500J Tailpiece found!!
Pretty frustrating - bike runs like a champ, starts first kick, idles, PV's cycle - but no tach signal.
Tried various tachs and only intermittent success- the same tach may or may not work. I doubt I have 7 bad tachs in the box
Is this a duff signal from the YPVS controller or whom ever supplies the grey wire with the tach signal? Should I just tap a lead off a coil (which lead from the coil, either?) for the signal and bypass the Yamaha box?
Can I drive any tach from a tap off one of the coils?
Oh the effing joys of a bike that's been sitting.
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
It seems extremely unlikely that you have multiple defective tachometers. Tach signal is grey wire from CDI.
It may be your short tach harness. Is it a harness that has worked with a 500 tach previously? I ask because I have tried testing tachs on my 500 using a 350 tach harness and TZR tach harness, both of which look the same as the 500 tach harness, and I could not get any tach to work. The harnesses look identical, put the pin locations in the plugs are different.
FWIW...I have had issues with tachs being sticky/lazy after sitting for a long period. Once they are revved hard a few times they begin to work properly, although it may take a bit of time to return to normal. I have opened many tachs and in my experience true tachometer failures result in a melted PCB.
Yeah, the tach worked previously. I had a FZR1000 (I believe it's a FZR) and the tach read double, so I hooked a pukka 500 tach up and it read correctly.
So I was getting ready to wire in the Baker Electronix signal adjuster and figure I would try the 500 tach 1 more time before I wired the Baker box inline.
And bugger me with a splintered fence post if the 500 tach would not work connected to wires that had worked just 5 minutes previously.
I took the tach to the bench and applied 12v and when I applied a small voltage to the signal terminal the needle swings up - so I believe the tach is good.
The full harness I am using is an OEM NOS harness I trimmed down a number of years ago - removed all the light sub harnesses etc. And this harness saw the bike through a track day without issues.
What should the voltage on Grey wire be for different RPM signals?
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
I have no idea about the grey wire voltage. Shouldn't it be just be reading pulses, so every 2nd stroke the CDI shoots the pulse through the grey wire? The faster the CDI fires the faster the pulses are sent.
Typically the FZR tach should have read half rather than double. As a 4 stroke tach it would only read every fourth stroke where the RZ would read every 2nd stroke.
I just spliced into one of the orange wires going to coils for the Zeeltronic
For tach feed or does the Zeeltronic replace the Yamaha CDI or YVPS?pstamper wrote:I just spliced into one of the orange wires going to coils for the Zeeltronic
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
Yes it replaced it. Could not get a tach signal so took a good pick and connected a wire from it to tach and started probing wire till tach worked. Was one of the coil feeds that worked.
OK, so I should run the grey input on the tach from one of the orange coil wires instead?
That sounds very doable.
Now that I got the bike looking exactly the way I want it of course it up and gets an electronic gremlin LOL
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
I am getting no joy with a using the orange coil wire to drive a tach, I will try the black wire today.
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
Black wire is electrical ground. You'll have no signal here. If you must use coil wire, it's only the orange one, but don't know if this works.
If you still use original CDI, tach signal is black/white that also goes to YPVS bloc.
Yeah - issue was the Baker Electronix signal changer unit. Tapped the orange and good 12v feed, TZ250 3YL tach works great, but reads double.
So I now need a way to half the signal.
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
Normally there is one coil for each cylinder and one spark at each rev on a 2stroke as in the TZ250.
But on RZ/RD500 you have only one coil for each cylinder bank.
Hence 2 sensors in the same circuit of the alternator which generate 2 sparks at each rev on all cylinders.
That's what we call "lost spark" in french.
So the ignition signal frequency is twice as expected by the tach you want to use.
Would be easier to use the RZ/RD tach.
Phil
Phil
I previously had an RZ500 tach, but don't want a street bike tach. I just think this build is better suited to the look of the TZ family of tachs.phildu31 wrote:Normally there is one coil for each cylinder and one spark at each rev on a 2stroke as in the TZ250.
Phil
O
I know the signal needs to be altered, that's why I have tried a Zeel signal box and this Baker box - neither seem to work as advertised though.
Also, doesn't the RZ500 throw 4 pulses out per rev rather than 2? The TZ250 tach shows 4000rpn at idle, I am sure I had adjusted the RZ to idle at about 1100 to 1200rpm.
So I need this signal to be divide by 4 rather than just by 2 it seems.
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
Hi. I understand the reason why choosing your tach.
In fact, that's the idea of the bike.
For the pulses per rev, you have 2 not 4. The 2 cylinder banks are synced with always 2 pistons at TDC at the same time and the 2 others at BDC.
The wasted spark occurs when piston is at BDC.
If you use Zeeltronic PCDI24V, you should be able to setup the number of pulses per rev for the tach.
Take a look at paragraph 21 page 10 here :
http://www.zeeltronic.com/manuals/manua ... CI-24V.pdf" onclick="window.open(this.href);return false;
Standard setting is 2 for RD/RZ but you should adjust it to 1 with your tach.
But as you say, things don't always work as advertised.
