Pulling off the generator to remove cranks
I have a proper puller for the flywheel, but I'm trying to do it without incident.
It will not pull off with a wrench, and am worried that if I use an impact I'll screw something up.
Do these pull off pretty hard?
Have to get cranks out for seals and possible bearings....sitting on the bench for six months hasn't seemed to do anything
I guess I need to get back at it....
73 TM/TS400
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
21 Aprilia RSV4 1100
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
Re: Pulling off the generator to remove cranks
Do some heating of the rotor while in tension.
Rubber mallet on the flywheel always worked for me.....
Be careful of too much heat, as that can destroy the magnets.
A lot of force is often required.
I always use grade 12.9 bolts for the 3 off M8, as lower grades stretch.
Sometimes the torque that is required swells the end of the crank so that the generator nut won’t re-fit! That will require filing the OD to allow the nut to fit.
Just tighten the puller until the flywheel comes off the taper.
Good luck with the removal.....
- Speed Freak
Use a lot of grease on the thread of the puller. If the thread is dry you will only waste your force to overcome the friction instead of getting force into the flywheel.
I'm using a hydraulic flywheel remover as we had often issues to get the flywheel off on different engines.
Most of the time because they were tightened too much.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Honda CBR 1000 RR SC57
Yamaha R1 RN04
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
I always tighten up the bolt on the pullers really well and give the end a good crack with a hammer, Thats the way I have been doing it since the dinosaurs...
Tighten up the centre bolt tight tight and give a good whack.
If only there was more free time.
With stubborn flywheels I tighten as much as I dare and walk away and leave it for a while. Come back and tighten again and wait a while. Repeat. It will come off eventually, often while you are in the waiting phase.
When installing any flywheel I always lap the flywheel to the crank before final installation.
Got it...
Put some marvel mystery oil on the threads, got it pretty tight, then hit it with a hammer a few times.
Tightened it up just a little more and it popped right off with no harm to anything
73 TM/TS400
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
Had to add.....those 3 bolts holding the inner generator cover on were a complete bitch to get out.
In order to get the cases split......The two inner bolts (under base gasket) at the lower edge of the lower cylinders has me worried as well...
73 TM/TS400
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
Is that the Yambits puller or another brand?
https://yambits.co.uk/rd500-flywheel-puller-p-6247.html
Yamaha FS1E 1975
Yamaha RD200 1976
Yamaha RD400 1977
Yamaha AS3 125cc 1978
Yamaha AS1 125cc 1979
Honda CX500
Honda MT125cc 1980
Yamaha TZ125G 1981-82
Zeger TC500cc 1983-84
Yamaha RD500LC 1985-87
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
- Speed Freak
Here a picture of my hydraulic tool.
In this case with a R1 RN04 flywheel which is a bit different as it only has a center thread.
This puller thread is a bitch, you will not get it off with a standard flywheel puller which is basically just a bolt.
Before you get it off 30% of the threads get damaged and then you are lost... Only chance to get it off then is to weld a nut to the flywheel.
In case of the 3 bolt removers just replace the center bolt by the hydraulic cylinder.
The flywheel housing bolts have thread lock on them.
Warm it up before removing them.
And for the 2 bolts at the front you need a good tool as they have a small head and the hexagon is not really deep. Try to apply torque only and no other forces. I like to use a T-bar instead of a ratchet for such cases.
And if the hexagon is destroyed... A hammer and a Torx are your best friend.
Take the next size torx and hammer it into the hexagon as deep as you can. If you feel that it starts to turn in the hexagon take the next size torx.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
The puller I used is older than the engine...It was my dads originally and he probably bought it some time in the 70'sChequeredFlagRacing wrote: ↑Sat May 23, 2020 3:23 amIs that the Yambits puller or another brand?
It worked for the job I needed but not designed specifically for the job.
The two crankcase bolts....I ended up drilling the heads off. Then when case was split the rest of the bolt came out easy with a vise grip.
73 TM/TS400
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
78 GS1000E
80 KD80
82 Katana
84 RZ350
84 RZV500R
86 GSXR1100
86 1100 sportster
88 FZR1000
89 RGV250 VJ21 SP
90 RGV250 VJ22 SP
91 TZR250 3XV2 SP
96 RGV250 VJ23 SP
99 RS250
02 Hayabusa
16 KTM 390 Duke
17 KTM 1290 SDGT
I am reading this thread now since I also currently try to remove the flywheel of my recently acquired 1GE. The engine was never open, so I guess the flywheel was mounted in the factory and never removed since. I am using the same flywheel puller that is shown above, so far with no luck. I would never hit the puller with a hammer since this force directly impacts the crank??? I will just leave under tension now for a while after I sprayed WD40 onto the joint, hoping it creeps in. I also only used 8.8 grade bolts which have stretched noticeably, so will need to get 12.9 grade bolts.
