Yamaha RZV500R Carb Balancing
Rode it last year and it ran fine. Bought the air flow meter late 2019 to check air. Now I've got around to tuning the carbs. Left lower pot was hardly breathing. Last part of the video shows all four balanced
https://www.youtube.com/watch?v=LQt6VN_TNwU
Yamaha FS1E 1975
Yamaha RD200 1976
Yamaha RD400 1977
Yamaha AS3 125cc 1978
Yamaha AS1 125cc 1979
Honda CX500
Honda MT125cc 1980
Yamaha TZ125G 1981-82
Zeger TC500cc 1983-84
Yamaha RD500LC 1985-87
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Re: Yamaha RZV500R Carb Balancing
Idle is too high.
It should run fine at 1200 rpm and needle near the number 2 for the four carbs.
![:smt023](./images/smilies/023.gif)
Idle to sort so not unduly worried. Will be rechecking air flow then I'll set idle
Yamaha FS1E 1975
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Ok.
First of all, balance the two banks at full open throttle as in the manual.
Next synchronize the two carbs of one bank with the tool by adjusting the synchronizing screw.
Do the same for the other bank.
Finally adjust the two banks at idle equally with the idle screws.
Best get the book out then as the online video shows setting wide open after synchronizing
Yamaha FS1E 1975
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Yes, you're right, you can do these in any order.
But you will find easier to set up full throttle before starting the engine
Then once engine started if you modify the synchronization in a carb bank, you'll have to check/adjust idle speed.
![Very Happy :grin:](./images/smilies/icon_biggrin.gif)
do you have to blank of behind the carbs first as per one of the other posts using the meter ?
my bikes.
YL1 , AS3 (2) , YAS1 (2) , LC 350 ,
RD 400 , 400 DAYTONA , KH 250 s1 ,
CBX 1000 , RD 500 .
CBX 1000 , RD 500 .
I didn't
Yamaha FS1E 1975
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
No.
![:smt006](./images/smilies/006.gif)
Past Bikes Include
what was the reason for IGYEE4 doing it ?
my bikes.
CBX 1000 , RD 500 .
CBX 1000 , RD 500 .
carb sync .
by lgyee4 » Sat Apr 11, 2009 7:33 pm
my bikes.
CBX 1000 , RD 500 .
CBX 1000 , RD 500 .
Haha : the post dates from 2009 ... reason why the user doesn't exist anymore...
And there is no reason to blank of behind the carbs as it has already been answered.
thats great thanks . did you happen to see my new post on setting up carbs by any chance phil any ideas ?
my bikes.
CBX 1000 , RD 500 .
CBX 1000 , RD 500 .
when you set them with the meter and then give it a slight rev and test at the same time should all 4 readings still be the same ?
my bikes.
CBX 1000 , RD 500 .
CBX 1000 , RD 500 .
