I’m in the process of making some suspension upgrades to my 84 RZ350N, Racetech Springs/Gold Valves Emulators up front and Ohlins shock on the rear.
Can anyone tell me what the “tolerance” is on the Fork Damping Rod surface,where the “rebound check valve rides) After having the holes welded for the Emulator mod, unfortunately my welder knackered up the surface of the rod, while grinding off excess material(creating low spots)
It appears that the parts are no longer available.. Any input would be greatly appreciated!
Thanks in advance for your reply,
Cheers, TC
