RZ250R front brake master cylinder compatibility
Hi, I want to change my front brake master cylinder. The thing is that I'm not sure about that if the ones I've found on ebay are compatible, would you help me?
With this one i'm not sure about the bore size. It would be a problem?
https://www.ebay.com/itm/7-8-Clutch-Bra ... Swkl5XfNhv
With this one I'm almost sure that the bore size is correct but maybe there is something that I'm missing
https://www.ebay.com/itm/5-8-Yamaha-WR5 ... 1054506859
The point is that I don't want to buy something that is not compatible. If you have some brand or link that you are sure that works I aprecciate it.
Thanks in advance.
Leo
Thanks in advance.
Leo
Re: RZ250R front brake master cylinder compatibility
The first one is similar to the old Yamaha R1 master , these are copy of Brembo under licence and were found on a lot of bikes of the area including other bike manufacturers .
I had one on one of my LC , they are cheap used , your first link is for sure a chinese copy .
https://www.ebay.com/itm/1998-1999-Yama ... SwPX1c9C4H
I have an 84 RZ350 stock master cylinder in good shape. If it will work for you it is $125 plus shipping. I take pay pal.
Tim Steele in Front Royal, VA
genuine nissin is the best way to go
11mm will give you softer lever and more feel . but require more travel to get the pressure
https://japan.webike.net/products/21554403.html
13mm will be more pressure at the lever less feel and less travel
https://japan.webike.net/products/1448221.html
depends what calipers you have fitted ,
what is the master cylinder size you have fitted now ?
Agreed thats better value. You can also buy the OEM Yamaha branded 5/8 as fitted to the 85-on models new still for $130ish.
I have one from an FZ-07 on mine....
2.5 RZ350's
2018 Grom
2017 KTM 390
2017 FZ-10
1973 RT3
1974 TY250
plus many others
2018 Grom
2017 KTM 390
2017 FZ-10
1973 RT3
1974 TY250
plus many others
The calipers are the original ones as the master cylinder, thanks!nzminis wrote: ↑Wed Jun 12, 2019 7:37 am genuine nissin is the best way to go
OEM is 5/8"
What would you think about this Nissin?
https://www.ebay.com/itm/Hydraulic-Brak ... 1438.l2649
what are the banjo bolt for?
"Requires M10 x 1.25 banjo bolt (sold separately)"
Would this master cylinder fit? the original calipers will work?
Best regards
Leo
Best regards
Leo
i have 5/8 and 14mm fitted with brembo 4 pots and fzr 4 pots
dont like the 5/8 as it has little feel the 14mm is much better
i would go with a 14mm master with the 2 piston calipers
