RZ Frame modified MOTO3 project
Re: RZ Frame modified MOTO3 project
https://www.youtube.com/watch?v=ZxroJBRA038
This is today and Microsquirt Autotune is starting to lean the engine out in the right places
Sorry i have nothing to compare it to or even get a base map from so taking a bit of time but getting there ----Current Moto3 tech i think will not be even close the the HP this is putting out after i get it onto the dyno
- Moderator
Can someone please explain the 3 stroke concept for me. I'm lost.
I'm the last person that should be explaining anything technical.
My understanding is the plug fires every 2 strokes, instead of every 4 strokes.
The cams have double lobes to open/close the valves every 2 strokes, instead of every 4 strokes.
My pea-sized brain thinks the same engine should make close to double the HP.
The big question is why wouldn't the factories have done this long ago?
![:smt003](./images/smilies/003.gif)
Smoker you are bang on !!! Thank you for under standing what you are seeing
I am so many yrs building two strokes and so many building 4 and educated in many cnc and robotic controls so i think differenly not in paradimes (I just have to think differenlty to make stuff work dailey )
At best should be double the HP but even if it was just a 30 to 50 percent inprovement would be massive ---Makes a single sound like a twin and a 4 sound lke an 8 as the pulze is twice
In real terms it takes out the waste of the four strokes and conbined them into one rotation in 3 areas of control
Its not been easy and can it be improved more hell yes as GDI would remove fuel in a throttle body so if i had one of the big four backing what i could produce would be was easier
I have done so many experiments and not easy from your own garage
The Single engine alone was very well balanced so with it firing everytime very smothe and little vibration and the exhaust pluze amazing to be honest
Hopefully it will suceed and we get lots more enignes this way or just another time i have tried --But at least its running now and even learn alot about the Microsquirt ECU stuff which was good -------Again thank you and so many for comments and interest along the way
https://www.youtube.com/watch?v=2K2JRP67K5o
With Microsquirt heads up display running on the 3 stroker
- Moderator
Brilliant engineering. Well done sir.
Amazing! Excellent work. ![:smt023](./images/smilies/023.gif)
90 RZ Race Bike
86 RZ daily driver
85 RZ low milage
86 RZ daily driver
85 RZ low milage
Yes, please keep posting updates here. This is a great project.
https://www.youtube.com/watch?v=M2MgVDUW6tI
https://www.youtube.com/watch?v=V--BdD3PpCY
First of two parts of full update on were i am at with this project
Thank you for all the comments and help over the yrs
https://www.facebook.com/photo.php?fbid ... 0..&type=3
The Big RZ at Tandragee Road Race Northern Ireland
RZ at the Cookstown Road Race ---Northern Ireland
Ulster GP3 at the Armoy Road race July 2021 Northern Ireland
https://www.youtube.com/watch?v=UQMPjEElMA8
Lots of technical issues with the GP3 and another broken crank but alot of lessons learned
Thanks for looking and lots more to come this year
Any info on ulsterman???
Once again, I should have posted sooner. Thought about him and his projects many times.
Haven't seen posting from him since around May of 2022.
