Frame bracing
Re: Frame bracing
#16 Post by Smoker » Fri May 28, 2021 7:13 pm
Yellow and Black RZ wrote: Fri May 28, 2021 2:37 pm When you feel like she's going to buck you off loosen your grip and ride it out. Easier said than done.
Definitely.
I've always been sensitive to the flexing of the OEM RZ350 frame. Especially when hitting bumps/dips while cornering. Upsets the balance, and reduces the effectiveness of the suspension and tire adhesion. And I'm only 156 lbs.
Yamavarna wrote: Wed May 26, 2021 9:16 pmI do however need some input on the grade of steel to use; I’m thinking .125” 1018 what do you all think?
I guess it depends how much you're using, but I'm thinking .125" wall is too thick.
I added a fair amount of tubing, but thinner wall than OEM, not thicker.
Should also mention that a good steering damper has been a great improvement to counteract the flexible frame issues.
giron
Re: Frame bracing
#17 Post by giron » Fri May 28, 2021 9:12 pm
Here is the frame I will use with an RZ350 motor. I don't see any reason for frame bracing with my application
Image Image Image Image Image Image
1985 RG500(Walter Wolfe)
1984 IT490
1985 RZV500R
1997 VFR750
1992 FZR1000
RGV500
TZR500
TZR350
1990 RZ350
1971 Porsche911S
1973 Porsche-VW 914-6
Yamavarna
Re: Frame bracing
#18 Post by Yamavarna » Fri May 28, 2021 10:08 pm
I’ve already bought my suspension and and wheels so I’m sticking with the stock frame, tank and fairings, I may go with a aftermarket tail section. Although the trellis frame looks impressive (how do you get the motor out)? I’m going for the minimum amount of bracing for the best results; kind of what I have seen work 4 decades ago. I appreciate the input and I will take some pics and document it on here as I go because; someone smarter than me can hopefully point out my mistakes as I mock it up before welding.
giron
Re: Frame bracing
#19 Post by giron » Fri May 28, 2021 10:18 pm
The frame I’m using it doesn’t require frame bracing, but the ease of engine removal
1984 IT490
1985 RZV500R
1997 VFR750
1992 FZR1000
RGV500
TZR500
TZR350
1990 RZ350
1971 Porsche911S
Re: Frame bracing
#20 Post by Smoker » Fri May 28, 2021 10:32 pm
Yamavarna wrote: Fri May 28, 2021 10:08 pm(how do you get the motor out)?
I designed the bracing around the motor, so it can fit in & out without removing the head/cylinders.
giron
Re: Frame bracing
#21 Post by giron » Fri May 28, 2021 11:18 pm
Everyone should be able to see the ease of engine removal with the frame I’m using is easier than the RZ350 frame. Also the frame is an aluminum frame much stronger than the steel RZ350 frame. No need to go through the trouble of bracing the frame. If someone likes the tubular frame than buy an RZ-1 frame
1984 IT490
1985 RZV500R
1997 VFR750
1992 FZR1000
RGV500
TZR500
TZR350
1990 RZ350
1971 Porsche911S
Questo vecchio rz
Re: Frame bracing
#22 Post by Questo vecchio rz » Sat May 29, 2021 8:32 pm
Okay if ya wanna do it...some bracing around the
1.) steering head!
2.) Rear shock area,
3.) Steering stsbaluzer mount!
After that if you want to proceed with
1.) Engine mount area ( if desired)
2.) YES THE RZ FEAMYE CRACKS AROUND THE KICKSTAND MOUNT. Check the area.
3.)Variation of x tube bracing under tank area etc..
It's all been done...don't overthink it.
The 1st above ( steering/shock ) help ALOT! at speed.
RZ frame is perfectly adequate for s racebike...it is what it is 1970-80s tech...plenty fast, plenty capable.
Just doi it and be done w it👍
giron
Re: Frame bracing
#23 Post by giron » Sat May 29, 2021 11:45 pm
Look everyone. Yamaha has a frame with a brace. Yamaha probably thought it was adequate bracing with this frame. Now true this frame came with an RZ250, but it should be no problem installing an RZ350
1984 IT490
1985 RZV500R
1997 VFR750
1992 FZR1000
RGV500
TZR500
TZR350
1990 RZ350
1971 Porsche911S
Yamavarna
Re: Frame bracing
#24 Post by Yamavarna » Mon Aug 02, 2021 11:45 am
I’m in the process of bracing now; It’s actually pretty beefy in comparison to the lc I just bought! I’ve done the steering head area (it’s very solid now) and the swingarm mount, I’m thinking of using tubes in the shock mount area (if I have enough clearance around the chain). I’ve heard about the front motor mounts cracking but I can’t find any info on bracing in that area (or the side stand mount) so I’m kind of stumped and really need some help at the moment.
I’m also thinking of taking it to Dennis at CMR when it’s done to check that it’s still all lined up straight and square.
Moderator
Moderator
Re: Frame bracing
#25 Post by silverstrom » Mon Aug 02, 2021 2:16 pm
Yamavarna wrote: Mon Aug 02, 2021 11:45 am I’m also thinking of taking it to Dennis at CMR when it’s done to check that it’s still all lined up straight and square.
CMR was dissolved following the death of Denis Curtis. https://www.facebook.com/pg/CMR-Racing- ... 948/posts/
https://www.rushnellfamilyservices.com/ ... s/4493580/
Yamavarna
Re: Frame bracing
#26 Post by Yamavarna » Mon Aug 02, 2021 6:03 pm
That’s a terrible loss not only to his family and friends but the entire racing and motorcycle community. God speed
