Apologies for the size of all these pics. When I have a little time I'll go through and size them down.
Few things I've dug out today. Could not remember where my wiring harness was. Sat around thinking about it for a bit.
Remembered a box in the garage with my orig cylinders in it.
Funny thing was. When I rebuilt my RZ for the second time with GSXR750 front end, GSX rear wheel and cush drive I rode it for a bit until one day I seized up the right cylinder.
Luckily I realized what was happening, got the clutch in quick and shut it down. Pushed the bike home.
I have no idea what the cause was. I had the original carbs and did not rebuild them after the engine was rebuilt. My guess has always been a float bowl went dry.
While looking for parts I found a deal for a set of ported cylinders with pistons on ebay so I picked those up.
I removed the melted aluminum from the original cylinders with muriatic acid and used a 3 stone hone on a drill to clean up the cylinder. I remember doing this in my apartment. If only the landlord knew.
Bought a stock 1st over piston and was ready.
Installed the ported cylinders and a single carb kit from a banshee and proceeded to put a few hundred miles on the bike.
Original Cylinders.
- orig_cyl.jpg (137.77 KiB) Viewed 2071 times
Stock porting.
Aww, those are my old cat Motor's hairs. Miss that guy.
- orig_port.jpg (143.66 KiB) Viewed 2071 times
Current Cylinder Porting.
- ported.jpg (130.11 KiB) Viewed 2071 times
'85 RRZ350 - Hacked.
