Picking Up My 1984 RZ-350 Project Bike This Weekend
b-bike393
Re: Picking Up My 1984 RZ-350 Project Bike This Weekend
#76 Post by b-bike393 » Fri Nov 09, 2018 6:07 pm
I know that these mounts are for the front brake lines.
However, I have yet been able to find the "EXACT" location of where these are mounted securely to the bike.
I've seen several pictures of RZ's and these parts are located by the fender - fork area. But when I look at this area I can't seem to find the area where these would fit.
Or, am I missing an additional bracket for these mounts?
Is the fact that I'm using the R-1 front calipers instead of the original RZ calipers have anything to do with my inability to locate the mounting location?
Little help....
ImageRZ Brake Part 1 by Boyd Koehler, on Flickr
2015 Yamaha FJR
Setup for multistate riding
2010 BMW F650GS :smt003
My dual sport bike
Finished Rebuilding - Restoring My 1983 RZ350
Rebuilding a 1980 BMW R65 with my daughter
It will be her bike when we're all done :smt041
Yellow and Black RZ
#77 Post by Yellow and Black RZ » Fri Nov 09, 2018 6:58 pm
'85 RRZ350 - Hacked.
b-bike393
#78 Post by b-bike393 » Fri Nov 15, 2019 2:24 pm
Spent time fixing the road rash on the right expansion chamber.
Followed the original weld lines on the pipe to help camouflage the repair.
Where the repair welds didn't follow those lines, I feathered those smooth.
For some dumb reason I didn't take pictures of the final results before hanging the freshly repainted pipe back on the bike.
Suffice to say, that when the Yamaha Dealership seen the bike, they couldn't see where the pipe was repaired.
The old rash.
Before I cut the old metal away I drilled each corner to keep the post weld procedure heat and vibration stress to a minimum.
First bit of formed sheet metal.
I used slightly thicker metal so when I welded it onto the pipe I spent more residence time on the PRIME metal rather than the PARENT metal.
Doing this in two sections made the repair much easier.
Rear section being removed.
Again, I drilled all corners to remove stress.
Formed the rear section.
[url=https://flic.kr/p/2hL8QEB]Image
2015 Yamaha FJR
My dual sport bike
tacky1
#79 Post by tacky1 » Fri Nov 15, 2019 2:27 pm
That is a nice tidy job on the exhaust, :smt023
kobra
#80 Post by kobra » Fri Nov 15, 2019 5:46 pm
I love it when people pay attention to detail. Good work.
#81 Post by JonW » Fri Nov 15, 2019 6:05 pm
Great work. not many of us out there who will repair pipes like this so its very good to have another in the 'save the spannie' club :)
b-bike393
#82 Post by b-bike393 » Fri Nov 15, 2019 7:53 pm
Really... All it takes is time.
Time to think about how best to do it.
Time to re-think everything.
Time to draw out the pattern on the pipe.
Time to cut out the pattern on craft paper.
Time to lay the craft paper on the pipe to check for proper coverage.
Time to lay out and cut out your pattern on the PRIME metal
Time to form, reform, reform and reform the PRIME metal so it lays perfectly over the damaged area.
Time it takes using a scribe to outline on your pipe where the new PRIME metal piece is going.
Time it takes to drill the holes at each corner. (do not drill outside the scribe lines. I did on one hole and had to carefully weld that area due to not having metal there)
Time to shape, trim, reshape, trim again the PRIME metal so it fits perfectly into the cut-out.
Time to set up the welder so you don't melt through the PARENT or PRIME metal.
Time to clean the oil residue away from inside the pipe around the whole area you intend to weld to keep oil from contaminating the weld.
Time to tac weld the PRIME metal into place so it best fits the circumference of the pipe.
Time to stitch weld (1/2 inch weld, stop. move far away from that weld and run another 1/2 inch weld, stop) the entire circumference of the PRIME metal into place.
All that time spent is so you don't warp the PARENT metal of the pipe.
Time using a 180 grit sanding disk on the pneumatic angle grinder to feather out the weld without going too deep into the PRIME or PARENT metal.
Time using a buffing pad on the pneumatic angle grinder to completely blend in the welded areas.
It's a good thing I had two full days to get this project done.
Worth every second. :smt003
2015 Yamaha FJR
My dual sport bike
#83 Post by JonW » Fri Nov 15, 2019 8:00 pm
b-bike393 wrote: Fri Nov 15, 2019 7:53 pm Really... All it takes is time.
:smt023
Evans Ward
#84 Post by Evans Ward » Fri Nov 15, 2019 8:15 pm
Cue Pink Floyd. Great work BTW!
kpke
#85 Post by kpke » Sat Nov 16, 2019 12:25 pm
You make it sound so........easy :smt011
Very nice work :smt023
b-bike393
#86 Post by b-bike393 » Sat Nov 16, 2019 3:02 pm
kpke wrote: Sat Nov 16, 2019 12:25 pm You make it sound so........easy :smt011
Easy, no. Fun??? Absolutely! :smt003
2015 Yamaha FJR
My dual sport bike
b-bike393
#87 Post by b-bike393 » Sat Sep 04, 2021 1:09 am
ImageRZ PLASTIC 2021 by
[url=https://flic.kr/p/2mkYDay]Image
RZ TANK 2021 by [url=https://www.flickr.com/photos/155240266@N03/]
I just talked to the paint shop ( I have free use of his paint booth ) and I'm clear to get this stuff in.
My daughters 1983 BMW R-65 tank as plastics need a bit more work than I'll get everything in the booth and shoot the color.
Getting really excited to finally get my RZ finished!
2015 Yamaha FJR
My dual sport bike
b-bike393
#88 Post by b-bike393 » Fri Sep 08, 2023 10:37 am
We've had important family issues keep me away from my RZ project.
This last week I finally finished shooting the paint and clear.
I can't say enough positive things about the graphics that rzsunlimited has available.
Their product is amazing and their customer service is outstanding.
I have a few remaining pieces being delivered and by the end of October this 8 year project will be compete.
The paint was shot in the temporary paint booth in my garage
The front fender doesn't require graphics so it was already done.
Here's what the paint, clear and graphics look like.
2015 Yamaha FJR
My dual sport bike
tacky1
#89 Post by tacky1 » Fri Sep 08, 2023 4:46 pm
Really nice paint job. I’m going with the same colours on my current build. Love it 👍
75RD350rider
#90 Post by 75RD350rider » Sat Sep 09, 2023 1:40 am
Top notch work!
Tim Steele in Front Royal, VA
