Rd350 Engine Tzr250 1kt
Re: Rd350 Engine Tzr250 1kt
I decided to paint the painting, I dismantled every motorcycle, I passed paint remover on the painting and I had a great surprise, the painting had several cracks, I had it soldered with Tig and reinforced so as not to have problems ... while I was thinking about what to do in the Engine, that's when I met a friend who was working in Japan and helped me a lot ....
- pistao 043 - Copia - Copia.jpg (80.8 KiB) Viewed 5095 times
- IMG_20131003_211611.jpg (89.76 KiB) Viewed 5095 times
- IMG_20131003_211628.jpg (97.29 KiB) Viewed 5095 times
https://www.facebook.com/marciel.fernando.58" onclick="window.open(this.href);return false; .............Two Stroke Always.....
Yes this inside the air filter is grass
- IMG_20131115_184606.jpg (112.46 KiB) Viewed 5095 times
- IMG_20131115_184516.jpg (106.91 KiB) Viewed 5095 times
- IMG_20131115_184549.jpg (96.75 KiB) Viewed 5095 times
So talking to my friend Leandro from Japan he advised me to change the engine, that's where the engine came from the tzr250 1kt, the first change in the bike. He then dismantled the engine and sent me. engine and electrical complete
- 1780566_735105313180920_8045374_o.jpg (99.37 KiB) Viewed 5095 times
- 1611855_729217943769657_808082082_o.jpg (130.19 KiB) Viewed 5095 times
- 1611843_729217953769656_193267890_o.jpg (121.78 KiB) Viewed 5095 times
- 1616217_735105253180926_1834468675_n.jpg (112.1 KiB) Viewed 5095 times
- 600x450-2014012300072.jpg (94.61 KiB) Viewed 5095 times
- 600x450-2014012300070.jpg (134.58 KiB) Viewed 5095 times
- 1603543_738652522826199_1095232050_o.jpg (147.17 KiB) Viewed 5095 times
- 1617853_735105099847608_614791765_o.jpg (134.41 KiB) Viewed 5095 times
- 1616441_738656989492419_1524698444_n.jpg (100.38 KiB) Viewed 5095 times
Considering the great difficulty found in finding parts, with good prices, and of quality had to make some changes in the bike, It is not easy to find tires, rim 18, and tank without rust is very rare, until you find but for you to have nostion How expensive! A full fairing used are asking for 3,000 dollars, before that I started to look for parts for improvements, and that were easier to find
...significant changes
- 20150803_110209.jpg (131.36 KiB) Viewed 5047 times
That is significant! Parts for that motor can be found from yambits for reasonable prices but don't buy the engine seals from there.
evan_calgary wrote:That is significant! Parts for that motor can be found from yambits for reasonable prices but don't buy the engine seals from there.
Why do not you recommend buying the engine seals?
Chassis modification
- 20150520_113149.jpg (64.07 KiB) Viewed 4998 times
- 20150520_103741.jpg (79.33 KiB) Viewed 4998 times
- 20150520_103731.jpg (77.88 KiB) Viewed 4998 times
Because they're crap and leak early.Marciel wrote: Why do not you recommend buying the engine seals?
Only use OEM Yamaha here.
MK wrote:Because they're crap and leak early.Marciel wrote: Why do not you recommend buying the engine seals?
Ok sir.. thank you so much. This site is very good. I did not know
...Unfortunately this tank did not work
- 20150521_125029.jpg (73.45 KiB) Viewed 4915 times
- 20150521_125014.jpg (67.74 KiB) Viewed 4915 times
- 20150521_125006.jpg (69.33 KiB) Viewed 4915 times
I tried but frame B does not dock correctly
- 20150522_125200.jpg (67.47 KiB) Viewed 4915 times
I decided to continue with frame B and buy another tank
- 20150522_125346.jpg (70.58 KiB) Viewed 4915 times
- 20150522_125338.jpg (69.1 KiB) Viewed 4915 times
- 20150522_125328.jpg (65.43 KiB) Viewed 4915 times
