Finally logged to the forum I have been reading so much.
It's been a long ride with my RD bought her in boxes 9 yrs ago, 6 yrs to build her up and now 3 years tuning and riding
![:smt003](./images/smilies/003.gif)
The tuning was like this:
1. all stock, custom pipes and boos ports from intake to transfers ->revved 12000RPM+ no power in 5. and 6. gear (pipes to short, bad math)
2.pipes got extra length on belly for temp. fix, head o-ringed, squish 0.9 - 1mm with 11° -> max 11000RPM but pulls 5. near top RPM, 6. no power
3. pwk 28mm carbs with power jet, honed cylinders new prox pistons, clean up porting with slight transfer reorder of opening (boost, main, secondary), reed valve moded for single petal carbon 0.4mm -> massive improvement in lower revs, pulls harder all the way top speed slightly higher
4. new set of pipes, this time with better math and more knowledge, remapped pv controller, rejeted carbs -> holy s... 1. front wheel up, 2. harder throttle -> front wheel up, 3. slight bump on road at 130kmh front wheel up all the way, pulls 6. gear like it's 4.
and this is where problems start, with old pipes pilot 32, main 142, needle middle position, new pipes with a lot more volume 38 pilot, main 155, needle second from top because around half throttle there was sputtering now clean and harder pull.
But on wot lean the same color with 142 and 155 main (power jet is around 20) The main problem is a wall at 9800RPM it pulls from 4000rpm on 7000rpm starts ripping and hits a wall at 9800rpm like I pressed a brake. The pipe was designed for 9200RPM max power and wide power band transfers and exhaust also for 9200RPM and it should rev to 10000RPM. The wall scares me because it hits it so hard and constantly lean on wot in top rpm. Checked floats, fuel flows great, tank clean, no air leaks. The carbs are knokoff but first thing i did was disassemble them and reassemble and they are very good. I think it's the 11° squish and I have to much squish velocity... i fear to blow the engine so need to sort it fast.
If I remember correctly the head volume is 20cc with br8es - piston head volume gives 16.7cc. with 26mm exhaust from tdc 6.09 cr
pistons are 64.5mm
The PV opens from 3657rpm to 7676rpm.
Ignition standard (homemade programmable digital CDI in progress)
I was thinking that the bigger pipes make more compression and because of that correcting the squish to 0.9mm and 15° (with 11° I don't know what I was thinking)
