paint codes
- Contact:
paint codes
any one have paint codes for 84 RZ red and white
- IMG_0284 2.jpg (128.87 KiB) Viewed 4071 times
1978 RD 400
1979 Daytona
1978 RD 400
1979 Daytona
Re: paint codes
As far as I have seen there are no paint codes. There may be a match available from Colorrite (I think) but their paint is horribly expensive. They are one of the few companies with off the shelf paint for a number of vintage motorcycles.
Are you trying to match existing bodywork? If so you need to get a shop to match paint as the OEM color will no longer be correct.
If you are not trying to match OEM paint then find something that matches your replacement decals.
Most actual paint shops will have a gun they can use to paint match. It may take a couple tries.
I have been through this exercise for most of the RZ colors as well as Kawasaki ZX7s. It takes some time.
Alternatively, take it to a painter and they can charge you to sort it out.
Re: paint codes
http://www.rd350lc.net/pageCOLORcode.htm
ColorRite does match exactly to Yamaha codes. I have used it and it is perfect.
https://www.colorrite.com/product/yamah ... w-1752.cfm Enter your paint name or code or number in the search box.
Yamaha Paint Codes
Colour Colour Code Abbreviation
Silky White GE SW Use 5035
Stormy Red AJ SMR Use 5005
New Yamaha Black 6G NYB
Yamaha Black 33 YB
Faraway Blue NG FWB use 5555 (00NJ)
If yours is SW and SMR I have these on file. I use Matrix for my bikes. Solvent based.
Silky White / Stormy Red
FROM PPG
RED :76522
WHITE : 4576
FROM MATRIX
RED :76417
WHITE : 4471
FROM Sherwin Williams
60399 Color: Hellrot Ii
46517 Color: Pure White
If yours is Chappy Red and Clean White I have these from Matrix.I scanned NOS parts and have used this for RZ500 and TZR250 and it is 100% accurate. Clean white is Cameo White and Chappy Red is Prowler Red. These are 100% accurate to Yamaha codes. I have painted panels to match existing plastic and it was seamless.
Yamaha Paint Codes
Yamaha Black 33 YB
FROM PPG
RED :76522
WHITE : 4576
FROM MATRIX
RED :76417
WHITE : 4471
Re: paint codes
This is a brilliant post!! [smilie=punk.gif]silverstrom wrote: ↑Thu May 14, 2020 1:38 am http://www.rd350lc.net/pageCOLORcode.htm
Yamaha Paint Codes
Yamaha Black 33 YB
FROM PPG
RED :76522
WHITE : 4576
FROM MATRIX
RED :76417
WHITE : 4471
I have looked high and low for paint codes that I could have mixed locally. Positively outstanding post.
In your vast knowledge base, do you have the PPG code (or other) for competition yellow?
I cannot decide on what color to paint my 84. Originally yellow & black. Everyone and their brother has one of those. I tend to hang out on the edge of the envelope occasionally. Case in point the scheme I am thinking about:
I am assuming this is Silky White and the blues are (dark) Faraway Blue FWB and (light) French Blue FBL. Correct?
Going by the codes you have provided:
Silky White PPG 4576
Do you have the PPG code (or other mfg.) for Faraway & French Blue (assuming these are the blues in the photo above)?
Any tidbit of info that you can share would be extremely helpful!
Stan
2.5 RZ350's
2018 Grom
2017 KTM 390
2017 FZ-10
1973 RT3
1974 TY250
plus many others
2018 Grom
2017 KTM 390
2017 FZ-10
1973 RT3
1974 TY250
plus many others
Re: paint codes
Far Away Blue is the same color as New Holland Blue....yes, New Holland the tractor company. Strange, but true. Any NH dealer should have it.
I have no information on Competition Yellow, but if you use the forum search box I'm sure you'll find what you need. It has been discussed here many times.
Re: paint codes
Thank you for your information, and time!silverstrom wrote: ↑Thu May 14, 2020 6:04 pm Far Away Blue is the same color as New Holland Blue....yes, New Holland the tractor company. Strange, but true. Any NH dealer should have it.
2.5 RZ350's
2018 Grom
2017 KTM 390
2017 FZ-10
1973 RT3
1974 TY250
plus many others
2018 Grom
2017 KTM 390
2017 FZ-10
1973 RT3
1974 TY250
plus many others
Re: paint codes
You're very welcome
Competition Yellow from ColorRite. https://www.colorrite.com/product/yamah ... y-1741.cfm
Re: paint codes
It's interesting the Competition Yellow only appears in search and not by year/make/model.
It is a different paint number from the "anniversary edition yellow" found on the 2016 R6/R1
Thanks for posting that link. I wrote to them and never received a reply.
- Contact:
Re: paint codes
Wow thanks guys I am at the point of getting things ready to paint now I do not paint my self I have good friend that will be doing all of that I am just doing all the leg work to get the paint I haven't found a decal set to match my bike yet so far I do like the blue in the picture Whymee where did you get the blue sticker set and what colors are you using
1978 RD 400
1979 Daytona
1978 RD 400
1979 Daytona
Re: paint codes
P51,
I pulled that pic from the web. I do not know all the colors. That is why I asked above.
2.5 RZ350's
2018 Grom
2017 KTM 390
2017 FZ-10
1973 RT3
1974 TY250
plus many others
2018 Grom
2017 KTM 390
2017 FZ-10
1973 RT3
1974 TY250
plus many others
- Contact:
Re: paint codes
thanks whymee in all I am going to go with my stock coolers red and white but thanks for all the info it was a big help now I need to fined the striping kit for it not having much luck there
1978 RD 400
1979 Daytona
1978 RD 400
1979 Daytona
Re: paint codes
rddecals has all the OEM style decals. As said, colorrite is the only company that matches the OEM colors. I've got a can of the yellow sitting around here somewhere that was based on a scan of a NOS panel and custom matched.
- Contact:
Re: paint codes
Mark Olan at RDdecals is the best in the business. I use him for all of my Yamahas and Suzukis, including custom work. I've never been disappointed.evan_calgary wrote: ↑Tue May 19, 2020 10:41 am rddecals has all the OEM style decals. As said, colorrite is the only company that matches the OEM colors. I've got a can of the yellow sitting around here somewhere that was based on a scan of a NOS panel and custom matched.
