RZ 350 spark
RZ 350 spark
Hello everyone, My 84 RZ350 US model will not continue to run, more than a few seconds . Kick like hell on center stand and it fires than runs for a very short time .Then maybe 30 min.later starts for another 4 seconds. At first I thought it was fuel issue.I cleaned everything ,cabs etc to looking like new. After it quite ,taking the new plugs out , I Then I realized it has no spark. Every once in a while it has spark ,then nothing. Also the spark is weak when it does work as it will not take any gas above idle. I checked every connection ,kill switch and ground . Even bypassed the ignition switch ,same thing 4 or 5 seconds of run time.
Thanks Richard
Thanks Richard
Re: RZ 350 spark
Easy. Stator needs rewind, low speed coil.
Re: RZ 350 spark
Sounds more like the typical 29K-50 CDI cold solder joint failure.
Re: RZ 350 spark
Could very well be. My 83 would start and run and get a mile or two from home and start spitting and coughing and backfiring. It really felt like a fueling problem but was intermittent. Changing out the CDI (to another "working" 29K) fixed the problem.silverstrom wrote: ↑Thu May 12, 2022 12:28 pm Sounds more like the typical 29K-50 CDI cold solder joint failure.
Ken's Garage
Re: RZ 350 spark
Thanks everyone , I was thinking stator as my first thought ,I wasn't sure. Cdi will be my second thing to try .
Thank You
Thank You
Re: RZ 350 spark
Sounds familiar. It was my CDI and RZ's Unlimited repaired it. 5.5 years later no problem.
BA
BA
Re: RZ 350 spark
As usual I'd recommend a DC CDI in any case as
- it doesn't matter, if it was the stator or CDI
- it costs not much more than the price of repairing/replacing just one of them
- it adds the same amount of HP than a decent set of pipes
Re: RZ 350 spark
OK guys, heres my 2 cents worth. I also have NO spark on my 84 KR RZ. Read all about "fixing" or "repairing" it. Clamping a block of wood around it, really ???
These things are almost 40 year old technology !!! Plus are designed for running a bike with cats !!
Some guys put them in an oven to repair, You kiddin me ?? Cary told me he can fix it "without" opening it, ?? really ??? Id bet on that !!
Cut the case open and re-solder, You kiddin me ?
I just spent 3 hours trying to open the case cause I'm one of those curious guys that cant be told I cannot fix something. Well, I proved myself wrong !!!
You aint gettin that case open smothered in all that silicone, I don't care how smart you are or handy ! Cannot be done !!!
SO..... I'm just calling Ed Toomey and getting one pre programmed and ready to wire sent to me ! A bit spendy, but now days, what isn't ???
Ill let you know how it goes. Only 2 things an IC engine needs to run, spark and fuel, of course air. Oh, and compression.
Re: RZ 350 spark
There was a nice youtube video showing the process of identifying the joint to be re-soldered, soldering and re-install. The link was posted in this forum a year or 2 ago by Silverstrom. In the same thread, there was a diagram posted with a measurement of exactly where you need to cut the CDI to avoid damage.krrzowner wrote: ↑Thu Sep 01, 2022 7:43 pm OK guys, heres my 2 cents worth. I also have NO spark on my 84 KR RZ. Read all about "fixing" or "repairing" it. Clamping a block of wood around it, really ???
The reason that some people clamp a block to the CDI is that pressing on the CDI box externally simply forces the broken joint to make contact.
Silerstrom posted this link back in Oct 2021 https://www.youtube.com/watch?v=v7OG8v94eBU
