VForce 4 reeds
kpke
VForce 4 reeds
#1 Post by kpke » Sun Sep 18, 2022 5:29 pm
I have these in one engine purchased some time ago. Has anybody purchased these lately? There are so many counterfeiters on amazon and ebay. I would like to make sure I get "real" ones. From the manufacturer they are $258 plus maybe shipping and tax. Quite expensive. They are less $ most other places but how do you know if they are real or not before purchasing?
What else is anyone using nowadays?
I have several sets of other ones here but other than the boysen dual stage ones, I don't really know what they are and what their specs are. I may end up using one of these sets but would prefer VForce.
Thanks.
Jessy
Re: VForce 4 reeds
#2 Post by Jessy » Mon Sep 19, 2022 6:24 am
The genuine ones have rounded corners and the branding on the side of the Reed block, copies have squared corners and no branding, guess the best place to buy them is from a trusted source BP Racing/TDR, I’m from the Uk so don’t really know anyone your side of the pond.
If you search YouTube there are a few videos on there showing the difference.
I have tried the copies on my old hack and they have been fine but I don’t think I would risk them on a new engine.
Jess
Jessy
Re: VForce 4 reeds
#3 Post by Jessy » Mon Sep 19, 2022 6:35 am
Link below fake vs genuine
https://youtu.be/QTYD1rLsnIc
kpke
Re: VForce 4 reeds
#4 Post by kpke » Mon Sep 19, 2022 10:08 am
Thanks for the reply Jess. I've seen that video. Too many fkn scammers out there these days. :smt011
Any other comments people?
WFO ALWAYS
Re: VForce 4 reeds
#5 Post by WFO ALWAYS » Fri Sep 23, 2022 3:03 am
Hey Ken ordered mine from Rocky Mountain ATV on the 11th ! #V4144-2 $450 OZ with new tusk gaskets I'll let you know when I get them
kpke
Re: VForce 4 reeds
#6 Post by kpke » Fri Sep 23, 2022 9:15 am
:smt023
Edit: Wow, $450???
US $233.99 to AUS = $355.72 So $95 shipping???
WFO ALWAYS
Re: VForce 4 reeds
#7 Post by WFO ALWAYS » Fri Sep 23, 2022 3:53 pm
Yep !! I see they are on special now :( and i paid $7 each US just for the gaskets ! And It's not cheap freight from the states , so yeah big $$ for a small part
WFO ALWAYS
Re: VForce 4 reeds
#8 Post by WFO ALWAYS » Sat Oct 08, 2022 6:38 pm
Got my VFORCE 4 REEDS and they are genuine , purchased from Rocky Mountain ATV , cant wait to install
haj
Re: VForce 4 reeds
#9 Post by haj » Mon Oct 10, 2022 11:03 am
Jessy wrote: Mon Sep 19, 2022 6:24 am I have tried the copies on my old hack and they have been fine but I don’t think I would risk them on a new engine.
Could you feel any difference compared to stock reeds ?
I've got a set of those copies I've been meaning to try.
Jessy
Re: VForce 4 reeds
#10 Post by Jessy » Thu Oct 13, 2022 2:09 pm
I found it picked up a bit quicker and pulled a bit stronger, not huge but enough to notice
Jess
haj
Re: VForce 4 reeds
#11 Post by haj » Fri Oct 14, 2022 8:45 am
Jessy wrote: Thu Oct 13, 2022 2:09 pm I found it picked up a bit quicker and pulled a bit stronger, not huge but enough to notice
Thanks :) I better get them installed soon then :) The reeds in mine might be the original from 1983 for all I know :)
Evans Ward
Re: VForce 4 reeds
#12 Post by Evans Ward » Fri Oct 14, 2022 11:10 am
I tried a set of the 4’s when they first came out and I couldn’t tell any seat of the pants difference from the Banshee fiber reeds that I have used for years. I took off the 4’s and sold them. The Yamaha Banshee fiber reeds are a bolt on and cheap as chips as they say. My engine is lightly modified so maybe one could feel it with a heavy modded engine.
kpke
Re: VForce 4 reeds
#13 Post by kpke » Sat Oct 15, 2022 9:11 am
Thanks for the replies. For this build I ended up using some TDR reads I happen to have in stock.
Evans, that is an interesting comment about the VForce reeds. And next time I may go with the banshee parts.
VALVE REED
2GU-13613-00-00
by Yamaha
$13.77
I assume these are bolt on and you use it the stoppers? Or do you use the whole banshee reed valve assembly?
Evans Ward
Re: VForce 4 reeds
#14 Post by Evans Ward » Sat Oct 15, 2022 12:24 pm
^ Ken- the banshee fiber reeds are a bolt on. Stoppers are the same for both. Economical and they work very well! I’ve been using the banshee fiber reeds for about 15 years on my RZ and only had one failure and most likely the broken part of the reed was expelled out the exhaust.
Jessy
Re: VForce 4 reeds
#15 Post by Jessy » Sun Oct 16, 2022 11:01 am
The banshee Reed blocks are slightly larger than the RZ, 2mm inner and 3mm on the outside, larger windows, so for optimal performance you might want to change the block as well.👍
Jess
